20 Most Recent
Elite Pride Go Go Traveller Plus Electric Scooter - 3-Wheel - Heavy Duty Questions & Answers
Can i change the program speed on my elite hd power chair myself
Probably not. You need a programmer (a PP1) that will allow you to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased.
How do i change the program speed on my elite hd power chair
You need a programmer (a PP1) that will allow uo to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased
Go go elite traveler has a continuous beeeeeeep.
hi, so when you first turn it on, bleep bleep ? if so check the four connections on the rear axle and frame partvwhere it comes apart
mostlb likely a bad connection there with one of pins or sockets.
regards
gewizrepairs.co.uk
