20 Most Recent Pride Mobility Products Legend XL 4-Wheel Scooter w/55 AH Batteries & Charger/Flat-Free 13" Tires/22" Seat - Color Viper Blue - Gray Vinyl Seat Coverings Questions & Answers
2answers
What happens to my brakes if the motor fails on a Pride scooter?
the motor will automatically brake the scooter to stopped and keep it locked there until it is running again or put manually in neutral.
10/18/2022 11:01:55 PM • Pride Mobility... • Answered on Oct 18, 2022
Pride scooter victory 9 nothing happens when we turn on key. Batteries are charged. It did get wet would that cause this?
Usually when things electrical get wet they fail.
8/30/2021 11:02:18 AM • Pride Mobility... • Answered on Aug 30, 2021
I thank you all most sincerely, for your kind and helpful suggestions, But perhaps I didn't explain my question properly. I am the new owner of a GoGo mobility scooter. On the handlebars are the u
From a pure physics standpoint... The energy to climb a hill... be it from the steep side or the gentle sloping side is the same... It is just easier on your heart and joints to take the gentle slope... (assuming you have the time). ERGO: If treating the scooter like a QUEEN is your goal... DEFINITELY GO SLOW. Tat way you will have no idea if it has any weak spots when you need it to go fast (and you will). I'm old... I don't have TIME to waste! Carnac the Magnificent
3/28/2017 2:32:08 PM • Pride Mobility... • Answered on Mar 28, 2017
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
9/3/2016 10:51:06 AM • Pride Mobility... • Answered on Sep 03, 2016
I am trying to rewire the throttle pod. which is which? red? white? black?
Maybe too late for this advice but it is important to take a detailed photograph of the wireing before unplugging anything.
7/2/2016 5:57:48 PM • Pride Mobility... • Answered on Jul 02, 2016
2answers
Remove broken key from ignition
I'd recommend a dental pick.
6/1/2016 7:47:23 PM • Pride Mobility... • Answered on Jun 01, 2016
Pride hurricane will not accept charge
Hi not much info is there a red LED & green LED on charger...or is there a red LED & orange led on ?? Bit more info would help cheers
5/16/2016 1:17:35 PM • Pride Mobility... • Answered on May 16, 2016
Why wont my celebrity x 3 charge batteries ok charger ok
Hi check the main circuit breaker c photo push the white button in to c if it has tripped open cheers 24247946-renznejc2kf2ou0julsh2cxm-2-0.jpg
5/16/2016 12:41:01 PM • Pride Mobility... • Answered on May 16, 2016
Is there a way to set the speed to slow where it can't be changed?
Yes a technician with a programmer can set the control very slow so it is limited on how fast it can go. Otherwise the joystick is meant to be adjustable, so setting it to one speed only not possible. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
5/15/2016 6:35:31 PM • Pride Mobility... • Answered on May 15, 2016
Pride mobility scooter saying motor error code did not move for a day than works has happened several times
hi Linda, can you please tell me what model pride this is ? Regards Rob
12/5/2015 11:03:46 AM • Pride Mobility... • Answered on Dec 05, 2015
Have a chip in the paint at the front fender of my Pride Scooter, is there a Paint Repair Kit I can buy, the color is candy apple red, the scooter is brand new
Candy Apple paint is extremely hard to patch repair. It has a base coat of silver or gold and then multi coats of the candy apple over the top. You can get a paint that is meant to be a touch up for candy apple but you never end up with the same shade of color. Most of the time it will come out dark blood red anywhere that it over laps the old paint. I would contact Pride as they may use a paint that does not require a base coat.
10/27/2015 12:15:17 AM • Pride Mobility... • Answered on Oct 27, 2015
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
8/3/2015 2:31:57 AM • Pride Mobility... • Answered on Aug 03, 2015
Rear wheel wobble
Bearing probably.
6/21/2015 8:48:38 PM • Pride Mobility... • Answered on Jun 21, 2015
Victiry 9
Battery connections?
6/21/2015 8:43:59 PM • Pride Mobility... • Answered on Jun 21, 2015
My pride jazzy electric powerchair will not unlock on one wheel, it only has one lever in back to release both wheels
Your jazzy chair should have 2 levers. There is a lever for each wheel. if the other wheel does not have the lever, then you are missing the lever that would release the wheel. Have a local tech look at it and they may be able to get the parts needed to release the other wheel.
5/11/2015 7:33:12 PM • Pride Mobility... • Answered on May 11, 2015
Pride Mobility Products Legend XL 4-Wheel Scooter w/55 AH Batteries & Charger/Flat-Free 13" Tires/22" Seat - Color Viper Blue - Gray Vinyl Seat Coverings Logo
1 questions posted
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Mobility Products Health & Beauty
Most Popular Question
legend xl 4 wheel scooter w55 ah batteri
  • Health & Beauty
