20 Most Recent Leica Geosystems Leica TS06 FlexLine Total Station Series Questions & Answers
leica Geosystems Leica TS06 manual
Type the above into a "google search" and the first item listed is the actually download of your manual.
Leica Geosystems... | Answered on Mar 30, 2015
how can get puk for TSO6
Leica Geosystems... | Answered on Dec 12, 2014
Connect and get best solution of email related issues. Webmailhelps
Electronics -... | Answered on Dec 04, 2019
format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
Electronics -... | Answered on Nov 20, 2019
Mkv files to play correctly require quite powerful computer. Try mpg, MPEG codes but even those when used for high definition video my require some processing power.
Electronics -... | Answered on Nov 12, 2019
Flash memory probably corrupted, you may need to format to get it useable, you will lose data but you can try a data recovery app which should retrieve most of the data even after formatting.
Electronics -... | Answered on Nov 05, 2019
Change the region code for all DVD cd's through the supplier
Electronics -... | Answered on Nov 02, 2019
It's possible that you or someone has accidently changed the region code setting on the player.
If you type your model number and the words 'region code' into a search engine, you should find out how to reset it to your region or make it region free.
If that doesn't work there's an electrical fault on the machine.
Electronics -... | Answered on Oct 31, 2019
Tip
How to repair Motorolla Talkabout 250 antenna
I have just repaired four of these radios, with complete success.
You need a tube of black Stixall (currently £5.81 from Tool Station), a skeleton gun and a saucer of water with a good squirt of washing up liquid.
Take the back off the radio, take out the batteries and remove the rear cover by undoing the retaining screws using a screwdriver with a star shaped bit. Unscrew the circuit board now exposed using the same screwdriver bit. Remove the damaged rubber aerial with coiled copper core, being careful not to damage or distort the copper core. It lifts off one of the screw lugs revealed when removing the circuit board. Get rid of all of the old rubber.
Now put the end of the copper coil back over the lug (where it came from) and screw the PCB back on followed by the back of the unit.
Now form a new rubber cover to the copper aerial using Stixall, squirted into place. Squirt it down into the aerial housing so that it will get mechanical purchase from the body of the radio. Put on plenty, completely coating the copper aerial. Now dip your fingers in the saucer so that they don't bond to the Stixall and mold it into a smooth aerial shape. Leave it to cure for 24 hrs and then dust it with flour. Job done.
I have tested my repaired radios and they are great, the new "aerials" have lasted well. I am especially pleased that I don't have to throw them away.
Good luck - regards SJP
on Oct 16, 2019 | Electronics - Others
Plenty here;
https://ksp-electronics.com/en/product/view/5741-ta1319ap
Electronics -... | Answered on Oct 15, 2019
Error. Over Current - Peak current exceeded
Possible causes:
Motor has a short - Phase to phase or phase to ground.
Motor cable damaged/defective.
Motor cables too long.
Acceleration/deceleration ramps too short.
Damaged output phase of inverter.
EMI
Electronics -... | Answered on Oct 14, 2019
Three years is pushing the life of the batteries. Have them checked where your type of battery is sold.
Electronics -... | Answered on Oct 13, 2019
You can use Card Data Recovery. It is the professional SD card data recovery software. It can recover photos, video, audio and documents from SD card, miniSD card, micro SD card, etc. This program has two versions, one for Windows users, one for Mac users. You can visit its official website to have a look.
Card Data Recovery for Windows
Card Data Recovery for Mac
Electronics -... | Answered on Oct 11, 2019
it means you can't write new files or alter the files.
It is cs26466 ?
this has a password protection feature apparently
is it an sd card ? move the tab on the side of it
If it is a usb flash drive I do not know how you get pass the passwor dor how you enter a password when accessing it ?
Electronics -... | Answered on Sep 20, 2019
Write protect in flashdrive could mean chip problem if you cannot partition or reformat the usb drive..you can try usb low level format, partition application..be sure to back up files before doing so.
Electronics -... | Answered on Sep 19, 2019
When Ally starts chanting "I need my pack", it can become your worst nightmare. I can't find "the pack" but I'm guessing it's the keypad that you plug into her wrist. My bet is the pin/plug connectors in these dolls were not super awesome quality wise and sometimes didn't register they were connected (the program cards were a bit glitchy as well). Once the batteries need replacing, the doll needs to be reprogrammed hence the keypad connection request. Just a guess...
Electronics -... | Answered on Jul 26, 2019
I don't know how new these are, but there is one trick to try to recover a battery. Make sure it discharges completely(will not turn on at all, no matter how hard you try). Then charge it completely. Continue to discharge and recharge, (again, when discharging try again and again to turn it on till it will not come on at all).
This process should start to help the battery get back it's charging 'memory' and you should notice the battery last longer and longer with each charge. If this does not work, there is a problem with the battery. Good luck!
Electronics -... | Answered on Jul 14, 2019
Leica Geosystems Leica TS06 FlexLine Total Station Series Logo
2 questions posted
Top Leica Geosystems Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Leica Geosystems Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Leica Geosystems Electronics - Others
Most Popular Question
puk code unlock
  • Electronics - Others
