20 Most Recent
Black & Decker Gizmo C520 Iron Questions & Answers
Will not work, will not go on
see this steps use the VOM and fix it. God bless youIf the iron doesn't heat, make sure power is on to the outlet, check the power cord , 2) and check the thermostat and replace if necessary.
The iron heats well and
Before you go through the process of taking it apart, buy some clr or a similar lime and rust removal product and fill the iron with that, let it sit a while and then dump it out and fill it with water a few times. Often if tap water is used, internal deposits will form and block off the passages, same as what happens in your car radiator over time.Most steam irons work better if you use distilled water in them as there are no dissolved minerals in that. Most replacement parts cost nearly as much as the iron itself and it's generally not cost effective to repair them.
