20 Most Recent Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Questions & Answers
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
11/30/2014 8:47:26 PM • Bosch 24 in.... • Answered on Nov 30, 2014
Bosch diswasher e15 light
Most likely it is the flood switch trigger causing the problem. Many reasons for this but mainly it means there could be water leaked into the base of dishwasher where flood switch is located. Or if you have Aquastop fitted in the water inlet hose then the hose might have kinked due to age or being pressed between cabinet wall and dishwasher. Turn power off to dishwasher at mains plug and pull it out. Check hoses. Tilt it about 20 degrees to one side on a towel and hold for about 10 secs. This should get the water out. Wait an hour or so to dry any moisture in the base and then plug back in and turn on. This should reset the E15 fault.
4/25/2014 7:12:59 PM • Bosch 24 in.... • Answered on Apr 25, 2014
0answers
0answers
0answers
0answers
0answers
2answers
Hi can't find the instructin manual for my
I usually find some manuals on here after entering the model. You sure that is the right model? Look on the inside by the door. Good luck
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
2/28/2013 2:03:44 PM • Bosch 24 in.... • Answered on Feb 28, 2013
I have a bosch dishwasher classixx its less than a
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
2/18/2013 12:29:08 AM • Bosch 24 in.... • Answered on Feb 18, 2013
0answers
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
11/13/2012 9:09:45 PM • Bosch 24 in.... • Answered on Nov 13, 2012
0answers
2answers
I have a bosch dishwasher that wont drain
Question! Did u buy this from Bosch? If you did not, then your contract is with the Store you bought it from and NOT Bosch and you should be contacting them and they should sort the problem.
A blockage, can sometimes be solved by putting one of those diswasher cleaning tabs in the machine a couple of times and see if that sorts the problem for you.
I suggest do that first it is the cheapest option and then if that does not work ring who you bought it from whether that be a retailer or Bosch themselves.
9/9/2012 4:27:33 PM • Bosch 24 in.... • Answered on Sep 09, 2012
0answers
0answers
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
46 questions posted
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
bosch diswasher e15 light
  • Dishwashers
