20 Most Recent
Onan 5500 Microquiet Generator Questions & Answers
Will not run without manuely chocking
Sounds like the unit has sat, and carb gum, Try draining the carb bowl and re-filling. There is a screw at the base of the bowl. Also make sure when cold choke is closed. And it opens fully after 3 minutes. Check battery voltage on choke coil.
2/19/2015 12:45:37 PM •
Onan 5500...
Answered
on Feb 19, 2015
Cant run both a/c at same time
A 5KW is too small to run two HVAC at once, especially if they do not have interlock relays where only one at a time can cycle. It needs a 7KW for two HVAC units
4/16/2014 11:24:19 PM •
Onan 5500...
Answered
on Apr 16, 2014
Won't run both a/c at same time
It won't run two HVAC because it is too small a KW. 5.5KW is too small, especially if both have high compressor head pressures. You need a 7KW to effectively run two units, or have a relay control installed so only one can run at a time. It is shutting down on under frequency. If you keep allowing it to do so, you will damage the voltage regulator, which on that model is one integrated A1 control board and not cheap !
3/18/2014 12:00:19 AM •
Onan 5500...
Answered
on Mar 18, 2014
Onan 4000 not charging battery
Some Onan 4KW do not have auxiliary battery charge windings and rectifier. Are you sure you have one? If not you will need and external charger
Onan 12hdkcd error 27 and 13
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Rv onan rv runs but now makes a rackett when running was real quiet
Contact www.advanced-power-technologies (Cummins Dealer) with exact model and spec number. Also there are cold weather options, and cold weather models. Many people buy the RS units of the net, only to find they have been stuck with warm weather models, and they don't start. Does it show a code, or a code 45.
Hard starting
Again, what generator model? Onan have thousands. Be more specific please.
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "
Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
