20 Most Recent Bosch Exxcel WFO 2264 Front Load Washer Questions & Answers
Cleaning the detergent draw
bleach is naver a bad choice but you can also use white vinegar.. Hope that helps
3/15/2016 11:20:45 AM • Bosch Exxcel WFO... • Answered on Mar 15, 2016
2answers
Hi I have got bosh
Error F18 means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps
to solve it.
5/10/2014 12:46:00 AM • Bosch Exxcel WFO... • Answered on May 10, 2014
0answers
0answers
0answers
0answers
2answers
The fabric conditioner tray does
Bosch Exxcel WFO 2264 Front Load WasherThis video will show you how to keep your soap draw clear and how to service the partsPlease remember to subscribe to our YouTube channel for all appliance tutorialsa 4 THUMBS rating is appreciated for answering your FREE question..
8/6/2013 5:11:46 PM • Bosch Exxcel WFO... • Answered on Aug 06, 2013
2answers
Bosch Exxcel 1200 (WF02464GB) not heating
The machine only heats when it takes the detergent, all three rinses are cold only and this time of year the load will be very cold when it comes out. If the machine is not taking extra time (like a hour or two) longer to run a cycle, then there is no problem.If you want to check the heater is functioning, try this1 Put the dial to off2 press and hole the start button whilst turning the dial one click to left (easycare 30)3 release start and either two of the progression lights are lit or if it has a diplay should show 8.88 or 0.004 turn dial to 90 cotton, take the the long way round ie not thro the off or you will have to start again5 press start6 drum will fill and the heater will come on, wait a few minutes and if the heater is working ok you will hear a noise like a kettle boiling.The drum does not turn during the test to allow you to hear this without the movement of the drum obscuring the sound.If it sounds ok, cool. put dial to off, wait a second then select drain to get rid of the water in the drumAll the best
7/19/2013 5:54:26 PM • Bosch Exxcel WFO... • Answered on Jul 19, 2013
Will not fill with water
Sounds a bit obvious but have you checked isolation tap is on?? Sometimes if the tap is the small plastic type (red or blue) the plastic can break and although the tap looks like its in the on position the valve underneath is off, remove the plastic tap (should be a small screw holding it to valve) check the rectangular valve underneath is in line with the pipe, if not use a pair of pliers to turn on. If the problem is with one of the valves on the machine itself, try a cold cycle, rinse or prewash to see if it fills on a different cycle.
4/15/2013 11:17:12 PM • Bosch Exxcel WFO... • Answered on Apr 15, 2013
Bosch exxcel washing machine not heating water
Are you sure it's not heating the water? The only time it heats is when it takes the detergent, all rinses are in cold water only. To test the heater, put the dial to the OFF position, press and hold the start button whilst turning the dial one click to left (30 easycare) when the two middle lights come on or 888 in display (if there's a display), take your finger off the start, turn the dial to 90 cotton (the long way, counterclockwise, not thro the OFF) press start, the tub will fill and it will do a stationary heat, you should hear the element/water making a noise like a kettle boiling. Leave the machine like this for a few minutes. Put dial to off until the door lock disengages and touch the water to see if it's warm. Put the machine on drain to clear water. If there is defo no heat repost and I will give you step by step of changing element.Cheers Roni
3/2/2013 12:35:12 PM • Bosch Exxcel WFO... • Answered on Mar 02, 2013
2answers
Pump cap will not come
Hi
You will have to turn it to open the pump cap. Hope this helps...please elaborate and post back for further assistance.
Daniel
1/6/2013 9:25:57 PM • Bosch Exxcel WFO... • Answered on Jan 06, 2013
F61 code door won't open
Error E61 is generated when the door is locked but open.
Switch the appliance off.
After 5 minutes, use a thin screwdriver to push the lock to the right and then release it.
Restore the power, close the door and try the machine on a spin programme.
If you are still having trouble after this, let me know what actually happens when you try to use the appliance. The more detail you give the better.
Hope this helps
Let me know how it goes or if you need more help.
12/6/2012 4:48:42 PM • Bosch Exxcel WFO... • Answered on Dec 06, 2012
Bosch 1200 classixx trips fuse unit
Possible that the program controller unit is faulty, it is possible that the power supply is short and so trips the fuse.Remove the power panel and check for shorting, if so the program controller must be replaced.
6/28/2012 7:15:35 AM • Bosch Exxcel WFO... • Answered on Jun 28, 2012
Bosch Exxcel WFO 2264 Front Load Washer Logo
133 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
bosch exxcel 1200 wf02464gb not heating
  • Washing Machines
