20 Most Recent Bosch Classixx KGV28323 Bottom Freezer Refrigerator Questions & Answers
2answers
Bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
8/29/2019 9:39:07 AM • Bosch Classixx... • Answered on Aug 29, 2019
How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
4/22/2019 2:32:29 PM • Bosch Classixx... • Answered on Apr 22, 2019
Water leaking from bosch freezer kgu 34665 gb
Very little info to go on, but it would have to be water valve, lines going to and from valve, ice maker, or defrost drain leaking from being stopped up.
10/1/2017 1:04:37 PM • Bosch Classixx... • Answered on Oct 01, 2017
The red alarm light is on .i have a Bosch
Thank you Stefan29, really helpful!
11/15/2014 11:11:45 PM • Bosch Classixx... • Answered on Nov 15, 2014
Water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
6/26/2014 10:06:22 AM • Bosch Classixx... • Answered on Jun 26, 2014
My Bosch Intellignt Frostfree 44 mothaerboard is faulty. Can they be repaired?
If you don't find a way to get the board serviced soon, you should get the part number off the existing board and google it to find a replacement board. I can't imagine the board is terribly difficult to just replace outright.
1/9/2014 2:57:21 PM • Bosch Classixx... • Answered on Jan 09, 2014
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
177 questions posted
Top Bosch Refrigerators Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Bosch Refrigerators
  • Bosch Refrigerators
Most Popular Question
red alarm light bosch
  • Refrigerators
