20 Most Recent Bosch MMB9110 Porsche Designer Series Work Top Blender Questions & Answers
I have the Bosch blender and the dial doesn't seem to work it is just flashing red light. I have only used this blender once. So frustrating
Immediatly return it to your dealer if the user manual give no suggestions. Can be an armature/field problem
11/7/2016 5:08:59 PM • Bosch Blenders • Answered on Nov 07, 2016
0answers
Users manual
Be the first to answer 8/24/2012 5:16:30 PM • Bosch Blenders • Posted on Aug 24, 2012Be the first to answer
Bosch UM3 Blender drive coupling seems
if you are certain the coupling is defective you can purchase a new one at any local small appliance parts depot, you will require the make and model of your product.
5/17/2010 2:36:40 AM • Bosch Blenders • Answered on May 17, 2010
My blender won't blend
I have no idea what might be turning, but likely you do not have the blades seated if the shafts don't turn... IF the shafts turn, the welds or swaging of the baldes to the shaft have probably come loose due to overloading.
4/7/2010 3:11:01 PM • Bosch Blenders • Answered on Apr 07, 2010
Durabrand Blender TSK-9368AP. How can I get a replacement pitcher for my TSK-9368AP blender?
Jimmy LavinderYou are tagging a dormant unanswered post that is 10 years old!The section up at the top is for you to ASK the Original Poster a QUESTION before giving him an ANSWER. You can't get any parts for anything online without an email address and a physical address. These parts are never found in a store. Durabrand is a cheap company of the 'sell and run' variety. There are no spares.https://www.google.com/search?q=durabrand+TSK-9368AP+partsDump it and buy a Vitamix, a company that guarantees spares forever or even a Braun, or Oster that guarantees them for 10 years...
4/8/2024 12:18:36 AM • Blenders • Answered on Apr 08, 2024
Breville Antony Worrall Thompson BL3 Blender user manual
Olabisi. It is better to create your own question rather than tagging a 13 year old question in the area where you ask the OP for further information before committing to an answer. Stir function runs the blades at a much slower speed to incorporate ingredients slowly. https://www.kitchenaid.com/pinch-of-help... STIR. To stir ingredients in a blender, start with a low, slow speed and gradually increase it to a medium speed. Blend until ingredients are completely combined. Different Blender Settings and What They Do - KitchenAid ..
3/26/2024 4:25:22 AM • Blenders • Answered on Mar 26, 2024
I have a Waring WSB33 stick blender blade does not turn
Actually I do repair these stick types all of the time. The trick is getting the head off. Then its a simple Process to remove the shaft and clean inside and add bearings or bushings of needed. After removing the blade and blade holder, Remove the coupling at the top, then remove the 4 screws. After that you will see a aluminum washer. Stop here. To remove the head assembly, you need to make a large slide hammer like a split bearing. Lead or steel is good. Or a circle of cement 8 inches in Diameter and 4 inches thick. The inside hole should be as close to the diameter of the mixer shaft as possible. Cast it in two halves so when assembled it forms a ring around the shaft. Wrap this with lots of duct tape. also place a ring of duct tape around the plastic head where the cement will touch it. now wearing gloves, grab the metal base (or secure it to something with a chain or in the fork of a tree). Once secured, slide the weight quickly against the plastic head assembly. After a few hits the head should pop out. Then remove the shaft, replace the o-rungs in the center bearing, clean the unit & reassemble.Use Silicone as sealant when reassembling the body. There is no need to remove the lower seal assembly but clean it with a small bottle brush. I have included pictures of this procedure but im too ugly to make a You Tube Video. ;) These pictures are from my teaching tool and were cut to show anatomy. Theseafox Enterprises cimg5933-v4qv1bmfzokhu3d0grjs2y1r-d-0.jpg cimg5936-v4qv1bmfzokhu3d0grjs2y1r-d-1.jpg cimg5932-v4qv1bmfzokhu3d0grjs2y1r-d-2.jpg
3/20/2024 3:32:45 AM • Blenders • Answered on Mar 20, 2024
Prolectrix Soup Maker. My soup maker didn't heat the soup up?
Question edited for clarity. That is likely a failed heating element, failed thermostat, or worse case scenario, a failed control board. https://www.google.com/search?q=prolectrix+soup+maker+not+heating+up ..
2/6/2024 9:16:54 PM • Blenders • Answered on Feb 06, 2024
My B and D BL5000 blender doesn't stop when I press the STOP button. The motor goes when the cord is plugged in. Is this repairable? How? I have looked at the screws to get at it
the lock/unlock button on the Cuisinart Smart Stick CSB-75 blender may not stay locked when pressed in. The solution is to hold the blender in the palm of your dominant hand, press the low or high button and hold, then push and release the lock button on top with a finger on your other hand. The blender motor should start as soon as you push the lock button down and stay running until you release the high or low button. However, fix.com offers OEM Black and Decker blender parts and accessories, including rubber gaskets, jar bases, measuring cup lid inserts, and blade assemblies. You may want to check if the parts you need are available and replaceable. If you are unable to repair the blender yourself, you can contact Black and Decker customer service for assistance. They may be able to provide you with additional information on how to repair your blender or direct you to a local repair shop.
1/26/2024 4:05:54 AM • Blenders • Answered on Jan 26, 2024
Can I get a picture of the wiring I have Listed Type M 133. 734 Z Bamix. Took the top off and 1 wire was off
Send it back under the lifetime warranty on the motor. The motor is not working, right? https://www.google.com/search?q=bamix+blender+warranty ..
1/25/2024 6:07:33 AM • Blenders • Answered on Jan 25, 2024
GNC Live Well Blender BL3340. I need help finding the O-ring for it please?
Question edited for clarity. It appears to be an eBay special. you may be able to buy using the diameter. Shops that sell fasteners sell O-rings, but this is likely wider, so more a gasket. https://www.google.com/search?q=GNC+Live+Well+Blender+BL3340+replacement+O-ring https://www.google.com/search?q=GNC+Live+Well+Blender+BL3340+replacement+gasket ..
12/12/2023 5:00:45 PM • Blenders • Answered on Dec 12, 2023
Elite Cuisine EPB-1800 17 Piece Personal Drink Blender. It just stopped working, is there some kind of fuse?
"Elite Cosine" :>D I changed it for you and added '(what it is)'. Question moved from Elite Televisions. There may be a thermal fuse. But this is junk made in China. A complete new one will cost you $40 at BestBuy. If you can find a thermal fuse, you can replace it as a generic component by the details on it. https://www.google.com/search?q=Elite+Cosine+EPB1800+fuse ..
11/9/2023 4:09:46 AM • Blenders • Answered on Nov 09, 2023
Ninja Blender starts at low power and then stops when increasing the power?
That sounds like it is overheating. Does the red power light flash before it powers itself off? Units like this with an enclosed motor often have an internal fan as part of the motor and vents on the base to drive out the heat. Various other ideas here and a link to Ninja Kitchen Support https://www.google.com/search?q=ninja+blender+starts+at+low+power+and+then+stops+when+increasing+the+power ..
10/4/2023 3:53:26 AM • Blenders • Answered on Oct 04, 2023
What is the best blender for making smoothies with frozen fruit?
This looks Spammy, but the answer is Vitamix.Yogurt or liquid first and fruit on top and let rip!A blender is the only machine in your kitchen that can produce a beverage from chunks of ice and fruit in less than 60 seconds. And no other blender we've tested since 2012 can reliably make silky soups, spoon-thick smoothies, and stable emulsifications like the Vitamix 5200. Yes, this model is pricey, but we think its powerful motor, nuanced controls, and long-lasting reliability make it worth the investment...
8/11/2023 6:32:01 PM • Blenders • Answered on Aug 11, 2023
Ronson 8342 hand blender. Where can I get a replacement chopper blade please?
Question edited for clarity. Question moved from Firearms Optics. Is it Australian? We don't know it in North America. This link may work better for you than me in Canada! https://www.google.com/search?q=ronson+hand+blender+parts+list ..
8/3/2023 3:41:09 AM • Blenders • Answered on Aug 03, 2023
Blender parts for Bon appetit blender
I need the plastic piece that goes in the middle of the lid on a bone appetite blender serial num. BAPBL010
8/2/2023 9:15:50 PM • Blenders • Answered on Aug 02, 2023
How to fix a Kitchen Aid blender, Model KSB5WH1, that won't start
It can only be three things Switch Motor Broken wire (unlikely) How good are you with a screwdriver and a digital multimeter at testing components? https://www.google.com/search?q=Kitchen+Aid+blender%2C+Model+KSB5WH1 ..
7/8/2023 12:00:14 AM • Blenders • Answered on Jul 08, 2023
Bosch MMB9110 Porsche Designer Series Work Top Blender Logo
Popular Tags
1 questions posted
Top Bosch Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Blender Expert? Answer questions, earn points and help others
View Most Popular
Bosch Blenders
  • Bosch Blenders
Most Popular Question
replacement glass jug
  • Blenders
