20 Most Recent
Bosch TDA8340 Iron Questions & Answers
Bosch iron TDA8320/01 soleplate marked
pan scrub or brillo pad soft wire wool you could heat the iron up and use hot soapy water on a dishcloth but be careful not to burn fingers as the cloth will get hot aswell
Dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust.
It is a pretty common problem that can be minimized by using distilled water.
You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar:
1) with a cold iron, fill the reservoir with straight vinegar
2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity.
3) Refill iron reservoir with clean water and repeat as of step 2.
4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Light comes on but iron won't get hot?
The heating element of your iron is either busted or
disconnected. If the heating element is busted, just
replace it. If it is just disconnected, you can easily
reconnect it using a screw driver. So, you can go ahead
and open the iron using your screw driver. Keep us posted by sending your e-mail and vote for this solution.
Bosch sensixx 2400w
The cleaning process is to fill up, heat to max, then hold steam lever across to "calc and clean" position whilst shaking gently over a sink.
Manual is available to download from Bosch.co.uk.
The temperature control dial of my Bosch Sensixx x DA30 iron has become very stiff to rotate. How to make it easier to turn?
If the temperature control dial of your Bosch Sensixx x DA30 iron has become stiff, you can try the following steps to make it easier to turn:
- Unplug the iron and let it cool down completely.
- Using a soft cloth or sponge, clean the dial and the surrounding area to remove any dust or debris.
- Apply a small amount of WD-40 or silicone spray lubricant to the temperature control dial.
- Slowly turn the dial back and forth a few times to distribute the lubricant and loosen up any dirt or debris that may have been causing the stiffness.
- Wipe away any excess lubricant with a clean, dry cloth.
- Plug in the iron and turn it on to make sure the temperature control dial is turning smoothly.
If the stiffness persists or the temperature control dial is still not turning smoothly, you may need to take your iron to a professional for repair or replacement of the dial.
2/25/2023 6:01:00 PM •
Bosch Irons
Answered
on Feb 25, 2023
