20 Most Recent Delta RP17453SS Standard Diverter Tub Spout Brilliance Stainless Questions & Answers
Tip
Delta diverter valve
to remove the cartridge a pair of paint can openers works well to pry the stem out .
on Apr 30, 2016 | Delta RP17453SS Standard Diverter...
The diverter is supposed to leak a little bit, so it will disengage after you turn off the water. If the water is leaking out a little, that's normal. But if it is really leaking out you may need to replace the entire spout.
Delta RP17453SS... | Answered on Jul 11, 2015
The water stops at the spout .You can replace your tub spout with one that dosnt have a diverter. It isnt neccisary though ,the one you have is fine,jest dont pull down on the diverter.
Delta RP17453SS... | Answered on Dec 04, 2013
The spout can easily be replaced...
Check for a set screw underneath back at the wall...
If no set screw then simply twist the spout of by turning CCW...
Then find a replacement spout at your local HD, Lowes< or hardware and reinstall the new one...
The replacement spouts are so cheap that it is not worth trying to fix the old one..
heatman101
Delta RP17453SS... | Answered on May 21, 2011
that is the way they are made. they are pressure balanced to reduce the risk of scallding.
however there is an adjustment that will allow a little more hot water. if you remove the handle, there is a small plastic disk, remove that, under that you will see a small ring with what looks like gear splines... pull out slightly and turn counter clockwise a few notches. reinstall the plastic disk and test.
if you don't get enough hot water, adjust again. only adjust a couple of notches at a time. you don't want to scald yourself in the shower.
Delta RP17453SS... | Answered on Aug 06, 2010
I'm assuming the leak is in the wall somewhere between the on/off lever or knob and the shower head. It is a good chance that it is the mixing-valve. It could also be where the shower head screws into the drop-eared 90*. If it is the mixing valve, it is either ruined, or a bad seal that might be replaceable. If it is busted piping the wall will have to be opened up to replace it. Good chance that the arm to the shower head is leaking at the threads where it screw into the wall. Good luck.
Delta RP17453SS... | Answered on Mar 17, 2010
The hole is designed to let water out instead of going back into your wall. The spout needs to be taken off (unscrewed usually by hand) and tephlon tape needs to be put on the threads coming out of the wall. After this is done, screw the spout back on. Should be all set.
Delta RP17453SS... | Answered on Dec 31, 2009
If this is a single lever faucet, they have a plastic "geared "peice that is adjustable so the water can be very hot at a sink but will allow the
shower / tub to be set at a lower mixing temperature to prevent scalading someone. to get to it remove the center cap and remove the screw from the center and remove the outer knob that sets the hot cold mix, the "gear" peice is there, set it left or right by one tooth at a time and check it till you get the disired temperature, you can remove it totaly but then it will get as hot as the water heater puts out.
Delta RP17453SS... | Answered on Nov 08, 2009
There is an allen screw on the bottom of the spout. IF you do remove it then check the 0-rings for wear. Replace if necessary.
Delta RP17453SS... | Answered on Sep 22, 2009
The vacuum breaker could be defective.
Delta Plumbing | Answered on Oct 12, 2019
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
Delta Plumbing | Answered on Aug 21, 2019
https://www.deltafaucet.com/files/live/sites/delta/files/company/concierge/Touch_troubleshooting_guide.pdf
"Ifthesesolutionsarenotabletoresolvetheissue,pleasecontactourDeltaTech2O ConciergeTeamat1-844-923-5368
IFNOSOLUTIONABOVERESOLVESTHEISSUE,PUTFAUCETINMANUALMODEBYUNPLUGGING THEBATTERYBOXWHILETHEWATERISRUNNINGUNTILRESOLUTIONCANBEACHIEVED"
Delta Plumbing | Answered on Jun 09, 2019
You need to install the screw that came with item, it goes under the handle thru the extension and into cartridge. Refer to instructions.page 3.
qk5krxajihraoapoi3zsan40ueqbvcpnowdvswq5rplcc5jjjt9xtd0q73fiheilr206ekaef1bbswnqkaf4ggaabui7kgbwcaadeaaaafvpkvylsawb+ibgaa+ig8cwcqbqibaaa6yjjomwucgc8qdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacradeaaaaaqgranaaaaaaqgranaaaaaeqgramaaaaakqhraaaaaebkqdqaaaaaebkqdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacradeaaaaaqgranaaaaaaqgranaaaaaeqgramaaaaakqhraaaaaebkqdqaaaaaebkqdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacr8f8dkgsefmplxo4aaaaasuvork5cyii=
https://media.deltafaucet.com/MandI/88723%20Rev%20B.pdf
Delta Plumbing | Answered on Jun 05, 2019
seems like any dirt that gets in it may cut grooves in the disks and that is inly fixable by replacing them
Delta Plumbing | Answered on May 19, 2019
Open the battery case and realign the batteries with the positive and negative poles in the right positions according to the layout in the battery compartment. Close the battery compartment. Make sure it locks completely before continuing.
Locate the reset button, if any, on or near the battery compartment, after changing out batteries.
Push the red reset button to reset the faucet.
Test the faucet to ensure the reset corrected the problem.
Tip
Not all automatic faucets have red reset buttons. Some faucets just require inserting new batteries or realigning the batteries in the compartment to complete a reset. on the faucet. Check the instructions that came with your automatic faucet or locate the user's guide online at the manufacturer's website.
Delta Plumbing | Answered on May 08, 2019
There is normally a filter at the end of the faucet outlet. They usually unscrew. its usually a fine mesh screen with a plastic backing mount.
Delta Plumbing | Answered on Mar 22, 2019
Delta RP17453SS Standard Diverter Tub Spout Brilliance Stainless  Logo
Popular Tags
12 questions posted
Top Delta Plumbing Experts
Thomas F. Schneider
Donni Steen
john h
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Delta Plumbing
  • Delta Plumbing
Most Popular Question
very slow leak only weep hole
  • Plumbing
