20 Most Recent
Baofeng BF-888 S UHF 400-470 MHz Portable Handheld 2-way Ham Radio Questions & Answers
My Baofeng 888S doesnt squelch
Baofeng BF-888S Constant Static/Open Squelch??
http://forums.radioreference.com > threads > baofeng-b...
Feb 23, 2020 - Try long/short pressing the orange buttons on the side. One opens squelch to monitor.
10 posts ยท I think some programming went wrong on one of my new BF-888s radios, and now when it's powered ...
Squelch issue how do I fix? : r/Baofeng - Reddit
https://www.reddit.com > Baofeng > comments > squelc...
Jun 12, 2020 - The squelch can either work on signal strength or it can only produce audio from the loudspeaker when it receives the right ctcss tone or dcs ...
BF-888S kinda suck? Or am I doin it wrong? : r/Baofeng - Reddit
May 3, 2017
Got some BF-888s, what's this funny squelch tail/data burst on ...
Jul 7, 2017
Interference Problem/BF-888s RX light always active : r/Baofeng
Jan 5, 2021
Questions about the 888s : r/Baofeng - Reddit
Nov 8, 2017
More results from www.reddit.com
Problem with BF888S - Two Way Radio Forum
https://www.twowayradioforum.com > problem-with-bf...
May 27, 2021 - I suggest using the new software and resetting the radio to something very basic with full power, no scrambler, no tones, no shift and wide band ...
Squelch on Baofeng BF-888S - Two Way Radio Forum
Aug 7, 2021
Baofeng BF888 squelch help please - Two Way Radio Forum
Mar 22, 2022
Baofeng BF-888s HELP - General Discussion - Two Way ...
Dec 26, 2014
More results from www.twowayradioforum.com
People also ask
Not progaming
try to connect again if dont work stay coonnect the cable and close the program i persist whith prog. open disconnnect the cable and connect again. if no result go to milklor.com there are program and answers of baofeng problems and solved
Programming radios
You must use a compatible programming cable and software (such as Chirp) to program the radio, and the frequencies must be within the radio operating range [400 - 471 MHz].
BF-888s
Any one reading this post help please...cheers,Peter
Channel voice announcement
go into the programming software, settings & see if there is an option, if not it sounds like the radio is on its last leg
or at least try to a factory reset
Programming radio BaoFeng BF-888 S
This is a very broad question, however if you are just needing some instructions on how to program the Baofeng BF-888 I would start by Checking Google for an operators manual, However these radio's are much easier to program with software. Search Google for a software program called Chirp. I do believe it has support for your radio, and that will allow you to program your radio, for a more detailed tutorial, check youtube.
Can I clone 888s from another I have programmed
With the cable specified by the manufacturer, you may be able to do so. Many people have had problems "cloning" the Baofeng radios. Their instructions are not very clear. You may find better informatin if you GOOGLE the instructions for that radio.
Portable radios
the BF888 is NOT a vhf radio, it is a UHF radio so it will NOT program VHF frequencies
Portable radios vhf
1 is the least amount of squelch and 9 is the most. 9 requires more ratio power to break the squelch than 1.
I need a manual for a tk-uv2
This site lists available manuals for download: http://www.manualsdrive.com/results.php?lang=en&search=TEKOO%20TK-UV2&#.VL2L5FXF_CB
