20 Most Recent
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Questions & Answers
What is the factory carb setting for a pp3516avx
The factory uses tachometers to set the carb and should be used to adjust if needed. To get the unit in the ball park you can lightly seat the "L" needle and turn it out 1 1/2 turn then lightly seat the "H" needle and turn it out 2 turns. Then have your dealer fine tune the carb.
I want to buy and download Microsoft word 2013
go to amazon.com and type in search boxmicrosoft word 2013you can also use the search engines google.com,ask.com.bing.com and yahoo.comyou can also go to ebay.com and type in microsoftword 2013 in the search box
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Why pole saw wont saw?
There could be a couple of reasons why your saw won't cut.
The first thing I would check is to make sure you have your chain facing the right way.
The chisel edges should be facing forward, or in the direction the saw chain is rotating.
If this is not the problem, then I suspect the chain itself is dull.
