20 Most Recent Poulan Pro 42CC 2 Cycle Chainsaw, 18" Questions & Answers
Poulan S25DA-38CCM Chainsaw. What year is my chainsaw please? The serial number is 25798030.
Question edited for a lot more clarity and maker name! Question moved from Television and Video! 1995 https://www.google.com/search?q=poulan+s25da-38ccm+manufacture+date ..
12/7/2022 4:52:46 AM • Poulan Pro 42CC... • Answered on Dec 07, 2022
2answers
Need help with an old Poulan Pro 405 Plus Chainsaw please/
question edited for clarity. Question moved from Cars and Trucks category. Put in new gasoline and a new plug. Make sure it has a spark and compression. https://www.google.com/search?q=poulan+pro+405 ..
5/4/2022 4:05:49 PM • Poulan Pro 42CC... • Answered on May 04, 2022
2answers
Model # pp4218avx chainsaw
It is important to engage the hand guard into the brake mechanism before tightening the screws, if the brake is aready on prior to fitting you will need to remove the sprocket and possibly the clutch to get the brake onto the machine, as the band will be smaller than the drum, once on and engaged into the mechanism the hand guard will pull back to the top handle and load the brake, you can then refit clutch and sprocket.
10/23/2021 10:36:05 PM • Poulan Pro 42CC... • Answered on Oct 23, 2021
2answers
Poulan Pro Chainsaw(PP4218AV) worked for a while now won't start
It's possible that the carburetor diaphragm in the lower chamber has hardened or cracked. Does the primer bulb fill with fuel after several pumps? If not, try moving the line that comes up from the fuel filter to the carburetor over to the primer port that normally connects to the other carburetor connection. Try to pump fuel again--if successful, then there is blockage within the carburetor which should be cleaned with spray carburetor cleaner inside and out. There is a small filter screen inside the main body that can be easily plugged with stale fuel. Hope this helps!
9/2/2021 5:35:17 AM • Poulan Pro 42CC... • Answered on Sep 02, 2021
2answers
The chain has come off. I put it back but it is too loose. How do I tighten it
Should be a screw next to the bar. you can tighten it and it will tighten the chain. Keep in mind that the 2 bolts holding the bar and cover in place have to be loose to do this.
12/28/2019 11:36:06 PM • Poulan Pro 42CC... • Answered on Dec 28, 2019
2answers
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
10/9/2019 5:10:57 PM • Poulan Pro 42CC... • Answered on Oct 09, 2019
How do i find the model number on my poulan
If you entered the 42CC 18" it is a PP4218(AV, AVHD or AVL) Gas Saw Type 2. The letters after the 18 correspond to the type of chain tensioning system.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. Match the "Handle, Chassis and Bar Assembly" with your saw to complete the IPL.
An OM and less detailed IPL for your saw can be found here:
CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
2/22/2019 2:35:58 AM • Poulan Pro 42CC... • Answered on Feb 22, 2019
Where do the fuel lines hook up on 1993 gmc serria pick up
With the throttle body in place. The backside (facing the fire wall) has two hex fuel ports. The port closer to the passenger side is the fuel supply. The fuel port closer to the driver's side is the fuel return.
9/27/2018 3:15:18 AM • Poulan Pro 42CC... • Answered on Sep 27, 2018
HOW TO TAKE THE MAGNITO OFF OF A 306A POULAN CHAINSAW
I can't find your model number at Poulanpro.com but in all the chainsaws that I have worked on the starter rope comes in the cover which is held on by usually 4 or so screws. I suggest that you go to the site I listed and look at the 42 CC engine (they have a parts manual for it) before removing anything else. Let me know if I can help further.
4/29/2018 9:49:53 PM • Poulan Pro 42CC... • Answered on Apr 29, 2018
How much does a new magneto for a pouland pro 4800cc coast
Ignition modules run about $35.00 each depending on the year model and product.
1/17/2018 9:26:24 PM • Poulan Pro 42CC... • Answered on Jan 17, 2018
Service manual poulan 4018wt
Owners Manuals Add your model number and download the manual.
1/8/2018 10:07:02 PM • Poulan Pro 42CC... • Answered on Jan 08, 2018
How to connect fuel and air pipes to right place
12/12/2017 7:48:28 PM • Poulan Pro 42CC... • Answered on Dec 12, 2017
Fuel line diagram for a poulan 4218avx
12/12/2017 7:39:36 PM • Poulan Pro 42CC... • Answered on Dec 12, 2017
I purchased a 260 Pro
because you interfered with it , the warranty is void and if you have a blocked line ( unlikely) then any repairs are at your cost it could be a stuck valve under the primer bulb that is the problem so remove the bulb and check the valves operation
7/11/2017 5:25:05 AM • Poulan Pro 42CC... • Answered on Jul 11, 2017
I have a craftsman chainsaw
This is a common problem. The fuel lines can become brittle and fracture, or sometimes they swell and will not stay on their connections. The tube that connects between the carburetor and motor is likely used to pulse the fuel pump that is internal to the carburetor. The primer pulls the fuel through the carburetor drawing the air out. As the primer is stroked first air than fuel is pumped out of the carburetor. The output of the primer returns to the fuel tank. That fuel line appears to have failed or become disconnected in your craftsman. Either the hose has broken at or near the fuel tank, or has pulled out of the tank. There is a small hole in the tank for many machines. The hole is smaller(providing a seal) than the tube diameter requiring a minor force to squeeze the tube back in place. Look for the fuel feed tube that also connects from the fuel tank to the carberator. Any loose connections will allow air into the carberator and it will not beable to run. Important is that the fuel feed tube can not be switched with the return tube from the primer. Connected inside the tank is a fuel filter that protects the carberator from contamination. Hope this helps? craftsman_generic_fuel_line_no_model-g3tsbbegcg0qqxctamdb1tib-3-0.jpg image12549img-or-g3tsbbegcg0qqxctamdb1tib-3-2.jpg 25205151-pzxv2dmyt02yqunciumgycfv-4-0-g3tsbbegcg0qqxctamdb1tib-3-5.png
6/28/2017 11:08:41 AM • Poulan Pro 42CC... • Answered on Jun 28, 2017
5answers
I have purchased Poulon pro 42cc 18 inch chainsaw.
The chain needs sharpened or replaced. You can purchase the tools from any hardware store, and sharpen the chain yourself in about 15 minutes. Don't worry, your saw is just fine!
11/15/2016 5:29:57 PM • Poulan Pro 42CC... • Answered on Nov 15, 2016
Chainsaw want idle why?
Try adjusting the idle 5crew on the carb. Its usually marked with an [ I ] To get it just right, make sure your chain brake is off, screw in the idle 5crew, the saw will rev and the chain will start to turn. Now back the idle off until the chain stops moving and the engine is ticking over nicely.
5/5/2016 7:15:00 PM • Poulan Pro 42CC... • Answered on May 05, 2016
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
708 questions posted
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
chainsaw want idle
  • Garden
