20 Most Recent
Breville JE95 Juicer Questions & Answers
Where can I get a manual for the Breville JE95
This is the link that will bring you directly to your manual:
http://dl.owneriq.net/c/c917f4a7-2e69-40c4-9bbc-e00c4ba83628.pdf
If you would like, just highlight, copy and then paste the link in your internet address bar under a new tab.
Error message
I fixed my juicer that had this problem, the problem was the thermal fuse which is located directly on the motor with some plastic covering it. You can replace the fuse or do what I did and just cut off the fuse and attach the two wires together (no more fuse) and my machine now works again :)
I tried to turn on
there is inside a thermal fuse and it could have blown if wet, can be replace it is 1/8 x 1/2 " long .inside the machine turns off everything when blown , and purchased @ Radio Shack for about $ 5-8 dlrs rated @ 8-10 amps , need more info , if this works for you >
