20 Most Recent Breville JE900 Juicer Questions & Answers
The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
11/21/2012 9:49:10 AM • Breville JE900... • Answered on Nov 21, 2012
2answers
I cant get the filter out of my Breville JE900
hmm, i cant tell if this is the same as my juice fountain. mine just twists to the side and then you can lift both pieces out together. then the filter just falls out when i turn it upside down.
3/26/2012 4:05:47 AM • Breville JE900... • Answered on Mar 26, 2012
My juicer started smoking and
Sounds like the belt that drives the blades broke. You will need to bring it back to the store in which you bought it from if it is still under warranty. Otherwise, get on the Breville website, register your product, and then find out about the warranty and returns.
8/27/2011 5:35:51 PM • Breville JE900... • Answered on Aug 27, 2011
I cannot get the mesh
If you can, soak the mesh basket in some hot water, boiling if possible. Many times this will break up residue
5/4/2011 6:48:32 PM • Breville JE900... • Answered on May 04, 2011
My juicer is about 10
You might have been able to find a replacement seal for the top but if the bottom is leaking that means the seal is gone there as well and that means replacing the container. The real problem is finding any of these. And when you do the cost is going to be as much as a new unit.
I'm afraid the best advice is to replace the entire unit. The only thing is to make sure you buy a quality unit if you want to get any useful life out of them. A cheap unit is going to start leaking within a year or two (about 30 seconds after the warranty runs out) a good unit will give you hopefully another 5-10 years of use.Might cost more now but you won;t have to replace it that quickly either.
5/1/2011 12:43:25 PM • Breville JE900... • Answered on May 01, 2011
How to clean
I found this very enthusiastic and informative web blog. It answers the cleaning question pretty well. Makes me want to get one:)
http://brevilleje900juicer.ash.com/
8/22/2010 4:45:37 AM • Breville JE900... • Answered on Aug 22, 2010
Cannot twist off the filter basket of the breville
I had the same problem. It must juat got a bit stuck - I gave it a really good twist anti-clockwise and it came unstuck and popped lose.
7/3/2010 11:53:29 PM • Breville JE900... • Answered on Jul 03, 2010
HOw do i clean it?
flip down the lever to pull it all apart.
rinse out the lid, food pusher and base(that the mesh filter sits in).
scrub out the mesh filter with a dish brush or the included brush if you have it. be carefull the grater-like parts at the base are very sharp. make sure it's clean by holding it up to the light. if there are any particles left clinging to the mesh it will seriously interfere with the effectiveness of your juicing.
you can line the pulp collecting jug with a plastic bag so that you dont have to clean that out as well.
it's best to clean everything immediately. if for some reason you can't, at least rinse the plastic parts and leave the mesh basket to soak until you can get back to it.
if you have any dried food or staining on any of the parts then a soak in water with lemon juice in it (maybe the juice of 3 or 4 lemons) should help soften up particles and strip away stains.
hope this helps....
1/18/2010 5:24:37 AM • Breville JE900... • Answered on Jan 18, 2010
The blade has become blunt and needs replacement.
go to my site and download the last entry in PDF format. I will be removing this link in a couple of days so be sure to save itl.
http://tricia8765.fatcow.com/HELPGUIDES.htm
12/5/2009 10:06:39 PM • Breville JE900... • Answered on Dec 05, 2009
4answers
The machine wont work
We had a Breville juicer which we just recently used but after a few hours it stopped working. May I know if whats the problem with it. We tried to open it but we can't figure what cause the machine to stop.
8/10/2009 9:54:04 PM • Breville JE900... • Answered on Aug 10, 2009
Missing Parts
www.brevillle.com
7/31/2008 10:01:48 PM • Breville JE900... • Answered on Jul 31, 2008
Model JB90B. Where can I get a manual?
Breville no longer exists as a brand.
3/14/2021 3:23:35 PM • Breville Juicers • Answered on Mar 14, 2021
Breville JE900 Juicer Logo
42 questions posted
Top Breville Juicers Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a Breville Juicer Expert? Answer questions, earn points and help others
View Most Popular
Breville Juicers
  • Breville Juicers
Most Popular Question
juicer about 10
  • Juicers
