20 Most Recent
Jet - JJP-12; 12-inch Planer Jointer Combination Machine Questions & Answers
I have a Jet JJ-6CSX jointer. I felt the knves
First off, the stripped screw may be a major problem. If it is just the screw threads that are stripped, you are in luck. Try getting something under the screw head as you turn it out and pry at the same time (a putty knife maybe). Once out you can check both sets of threads (male & female).
You should not have needed to adjust the tables unless they were out of alignment from the factory or had been in use a long time. The first thing to re-do, is align the tables properly. Once that is done you can then go back to re-setting the knives.
My other suggestion is to ask someone who has knowledge in this to give you a hand. Maybe a local woodworker or woodshop or high school shop teacher.
How do I align beds on Jet jointer?
i found on some jointer/planers that this problem, is the way its designed. you can adjust the two feeds close but not close enough. what your supposed to do is push the wood thru one side with pressure on top and side(right hand), then when it touches blade slowly but steadily switch pressure part on the outfeed side. when you think anout it you are cutting an L shaped notch(until the end) so you dont want the side to be exactly parallel. table top jointers are tricky to use.
Blade guard for Atlas 6'' jointer
I can send you pics of the one I made from plywood for this same jointer. If you're looking for an original I can't help you there.
Need a manual for a
If you're still interested, please see
this answer and follow the links.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Tuckpointing brick, mortar won't stay in. have a
is the recess deep enough on the bed and perp joints if so is the mortar the right consistency.
a little tip is to wet the joints with water before jointing. it stop the mortar drying out to quick
What is the proper way to hold the masonry trowel?
On the website http://www.masonryforlife.comthey explain: "Learning to hold the trowel correctly is important and will make the job easier. Gripping the handle with four fingers and putting the thumb on top of the metal band (ferrule) on the handle is how most masons hold a trowel."
1 yard cement is how many cubic feet
kakima is 100% correct, but to add to it so you understand how he got that 27 cubic feet... you can picture a cube.
A cubic yard is 3 foot tall x 3 foot wide x 3 foot high.
(A cubic foot is 1 foot tall x 1 foot wide x 1 foot high).
So 3 x 3 x 3 = 27.
Rewiring switch
I do not have a clue as to what you have but a simple switch has two connections and you can connect either way.
