20 Most Recent
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Questions & Answers
37 horsepower vanguard voltage regulator what voltage is supposed to go to stator and what voltage should be at the other end while running
Motorcycles are usually fitted with a permanent magnet rotor type alternator that supplies a 3 phase alternating current to a combined rectifier/regulator, the DC output of which should be sufficient to charge the battery and supply enough current to power all the ancillary equipment.
A fully charged 12 volt battery in good health has a terminal voltage of 13.2 and the output of the regulator should be in excess of that or half for six volt systems.
Some motorcycle systems can be remarkably complex so it is best to use a wiring diagram to aid understanding. Motorcycle batteries won't tolerate a sustained high rate of charge so some systems provide a reduced supply until the headlamp is switched on - just one of the many possible complications that could be encountered with motorcycle electrical systems, ballasted rear lights is another...
9/27/2018 10:33:33 PM •
Briggs &...
Answered
on Sep 27, 2018
Breather blowing oil out
If there is a check valve in the breather it may be stuck. However this is usually indicative of broken rings or burned pistons(piston) . Compression bypasses rings and pistons causing excess crankcase pressure and oil spillage.
11/18/2017 5:09:39 PM •
Briggs &...
Answered
on Nov 18, 2017
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
5/4/2017 10:17:35 AM •
Briggs &...
Answered
on May 04, 2017
18 hp v twin will not run. It is gettng fuel to
There is a solonoid valve in the carburator that shuts off fuel to meet emissions standards. Be sure it is wired to be powered when key is in run position. You can hear a "click" at the carb. when the solonoid powers up.
2/4/2016 7:23:10 PM •
Briggs &...
Answered
on Feb 04, 2016
