20 Most Recent Bosch SG45 4500 Rpm Drywall Screwgun Questions & Answers
Sometimes you can wrap a piece of thin plastic or paper around the stem and shove it back in and will hold it in place,- other wise there is a spring steel clip that probable wore out and would need to be replace but it wont be fun
Bosch SG45 4500... | Answered on Nov 02, 2017
Because the tip is brand new or you don't have a magnetic ti. Try tilting the gun a little sideways before you pull it away from the screw. Sorta like tilting a sweating glass a little bit before you lift it off of a coaster so that the coaster doesn't stick to the bottom of the glass.
Jim
Bosch SG45 4500... | Answered on Mar 10, 2015
Just pull it out. If it is rusted stuck, get a pair of pliers on there and give it a yank. It will come out.
Bosch SG45 4500... | Answered on Jul 26, 2010
You have to replace the entire depth guage assembly (the front plastic pieces where the bit driver is). Unfortunatly Bosch does not make the individual pieces for this gun. Any Bosch service center will be able to supply you with this piece
Bosch SG45 4500... | Answered on Apr 14, 2009
I don't think a Dremel has enough power to do what your after. However there is a larger rotary tool made by several different company's mine is made Dewalt works great fairly inexpensive and will do what you need.
Drywall | Answered on Sep 30, 2019
The stud finders are not expensive but you can sometimes use a magnet to find the nails. Also you might try shining a flashlight across the wall. The putty put over the nails will sometimes show up. Last resort is to tap on the wall and try and hear the areas that have support under them.
Drywall | Answered on Jul 19, 2019
5/8 of an inch is recommended. You may be able to get away with 1/2 inch if you don't really care, but i would check with the building inspector first
Circles are hard to make, I had a lot of trouble when we decided to put recess lighting into the whole house. I wasn't able to find a tool that does all the cutting for you but what worked really well for me was a Goldblatt Drywall Circle Cutter. It doesn't cut all the way through the drywall, it just scores it so that all you have to do is cut from the center of the circle out to the edge and then snap off the pieces. Saves you tons of time trying to get those round edges to look perfect!
Drywall | Answered on Jul 17, 2019
Screws if you have not already used. Then as follows:
Joint compound
Joint tape
Then texture if desired
Primer
Paint
Drywall | Answered on Mar 03, 2019
you tape and mud the joints after hanging the drywall
Drywall | Answered on Jul 01, 2018
You can either measure up from the floor or the piece of drywall you just hang and then measure over from the wall or the piece of drywall you just hang or you can put the drywall in place and I ball behind it and Mark with a pencil and then cut it out with a dremel tool and you should be good from there. You might want to use a keyhole saw or a roto zip and a Rotozip is the best way to do it but it takes a little practice in order to control it
Drywall | Answered on Mar 01, 2018
many home improvement stores sell partial sheets . then you cut a plug the right size and spackle it in place .
Drywall | Answered on Dec 17, 2017
hi there.
Sink A Self-Drilling (Threaded) Anchor
  1. Mark your hanging point with a pencil.
  2. Tap the pointed tip of the anchor into the wall with a hammer.
  3. Once the tip is in the drywall, with a screwdriver, screw the anchor in until it's flush to the wall.
Fix-It Friday: Anchors Aweigh! How To Put Anchors Into Walls
womenyoushouldknow.net/fix-it-friday-anchors-aweigh-how-to-put-anchors-into-walls/
How to Install Drywall Anchors to Hang Heavy Stuff on Your Walls
How do hang an object using drywall anchors Google Search
Drywall | Answered on Nov 28, 2017
2 or 3 days, plus or minus depending on how fast the mud dries.
Drywall | Answered on May 02, 2017
Get you some heavy duty liquid nail or similar adhesive, put it in strings/loops, wait a bit, put rock on, hold a bit done
Drywall | Answered on Apr 17, 2017
Drywall sheets are 4 feet wide. Thus, each foot of a drywall sheet contains 4 square feet. Divide 10,000 by 4 = 2500 linear feet of drywall sheets. Add 5 to 10% for wastage.
Drywall | Answered on Mar 14, 2017
Tip
Cutting Drywall Like a Pro
Cutting drywall is one of the more easy cuttings that you will do when remodeling your house although you hear all kinds of horror stories of people making huge mistakes and having to re-hang drywall or use exorbitant amounts of putty to fix mistakes. Following just a few simple tips you can master the task of cutting drywall.
Most of the cuts that you will be doing will fall under the category of score, snap, cut. Because dry wall is fairly easy to cut, for a majority of cuts you will just need a scoring knife with just enough pressure to cut the paper and then you will be able to snap the drywall then you have to cut the paper on the back side and you are done.
For the major cutouts that you will be doing like doors and windows, the best way to go about doing them is to measure and cut the boards before you hang them. Its best to have someone help you hold the board in place.
There are two main types of saws that you will use a drywall rip saw and a keyhole saw. They each have their purpose and they should only be used for the purposes that they are meant for. The keyhole saw is for small cuts like holes for light fixtures, outlets and switches while the rip saw is for cutting drywall down to size like for doors and windows.
Once you have mastered the basics of cutting drywall you will be able to do more advanced home repairs and will spend less time worrying about cutting out pieces of drywall.
on Jan 30, 2016 | Drywall
Bosch SG45 4500 Rpm Drywall Screwgun Logo
4 questions posted
Top Bosch Drywall Experts
ray gallant
John Donghia Jr.
John Donghia Jr.
Are you a Bosch Drywall Expert? Answer questions, earn points and help others
View Most Popular
Bosch Drywall
  • Bosch Drywall
Most Popular Question
screwgun broken
  • Drywall
