20 Most Recent
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Questions & Answers
Briggs and stratton motor w/
If selled some capacitor or new ignition parts order it always with statement of the serial motornumber and the year of build , because of modifications on marketing technical dicisions can be made for your engine, that can prevent a next disappointment. may be for the problem a new sparkplug the supression capacitor can also be bad a bad sparkplug connection cable .are some small sugestions.
3/1/2018 4:18:49 PM •
Briggs &...
Answered
on Mar 01, 2018
No spark
sparkplug or a defect ignition coil, if the last option happens it is a very important that you should always note the serial number and year of age and the brand of the used engine because of marketing technical modifications can happen over time.
it happened in practice too often that some people just give up the model and then come to decide that there is no spark coming from the spark plug.
2/25/2017 4:55:21 PM •
Briggs &...
Answered
on Feb 25, 2017
Need to replace primer bulb on a briggs & stratton lawn mower
pull the bulb and retaing ring any way you can. don't try ti save them. you get a new retaing ring with the bulb. put the new bulb in then work the retaing ring in with a screw driver,clean everything behind the bulb before you put the new on in.
11/27/2014 3:07:40 AM •
Briggs &...
Answered
on Nov 27, 2014
FORD ikon engine
Maybe your converter is stopped up this is just one thing could be a fuel filter
2/9/2014 9:51:50 AM •
Briggs &...
Answered
on Feb 09, 2014
Spring hook-ups throttle free design carb.
Spring goes from throttle air valve to plastic lever under flywheel. Cooling fan on flywheel provides pressure to open/close throttle. As engine (fan) speeds up, pressure on lever causes throttle to close. As engine slows, throttle will open. System achieves an equilibrium very quickly.
hope it helps!
3/28/2012 3:58:51 PM •
Briggs &...
Answered
on Mar 28, 2012
