20 Most Recent
Cuisinart DLC-1 Mini-Prep Food Processor Questions & Answers
I need just the lid.
There is a small plastic piece on the lids 1-196 that slides into a slot in theback of the processer and is s safety interlock. unless your new lid will fit into that it will nto work. I know because i bought the wrong lid after the exact plastic piece broke on my original and I could not get the new one to work... right now my "work around" is to put both lids on.. the newer one does have the piece but its it the wrong place and I have to hold them while I use the processor.. sorry
Safety pin on food processor won't retract
It sounds like the safety interlock system on your Cuisinart 14 cup food processor is engaged, preventing the bowl from fitting securely onto the base. Here are some steps you can try to resolve the issue:
- Unplug the unit from the electrical outlet.
- Use a small, pointed object such as a toothpick to gently push the white safety pin up and out of its locked position. This may take some effort.
- Check the base of the food processor for any obstructions or debris that may be preventing the bowl from fitting correctly. Clean any debris you find.
- Reinsert the bowl onto the base, ensuring that it is properly aligned and twisted into place.
- Press the bowl down firmly onto the base until you hear and feel it click into place.
- Plug the unit back in and test it to see if the safety interlock system has been disengaged and the food processor is working normally.
If these steps do not resolve the issue, it may be necessary to take the unit to a professional repair technician or contact Cuisinart customer service for further assistance.
Cuisinart Food Processor (14 cup
For cuisinart food processors that won't shut off: with bowl off - not attached - hold OFF button down while plugging in. With a screwdriver or other implement, press the button that gets depressed on motor base when bowl is attached and snapped into place ( small flat rectangular piece that clicks the bowl into place. While still pressing OFF button, press this a few times times, unplug then release the OFF button. I tried several suggested combinations of button pushing and unplugging, and this seems to have fixed it!
