20 Most Recent Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Questions & Answers
2answers
I have a Tecumseh 12.5 hp vertical ohv engine
My 13.5hp ov358ea is .004 both valves. Would like to know model of your engine. I want to replace the non-adjustable carburetor of my 13.5hp ov358ea with an adjustable carburetor.
Retired Airline Mechanic
10/29/2022 10:41:54 AM • Mtd LAWN MOWER... • Answered on Oct 29, 2022
Huskee Supreme lawn tractor runs for about 20 minutes then engines stops like it is running out of gas.
if it restarts after it sits a while you need to check the spindels on the deck one or both may have bearings sezing up after the run and heat up.
1/13/2018 1:55:17 AM • Mtd LAWN MOWER... • Answered on Jan 13, 2018
I have 13.5 hp White Tractor that will not start.
Yes Will the engine turn over if turned by hand ? If so it probably is you starter that needs work on. You replaced the battery but are you sure it is fully charged? These are things to check before spending a lot of money.
12/29/2017 4:19:53 PM • Mtd LAWN MOWER... • Answered on Dec 29, 2017
When i push brake belt comes off. need to know what to do?
sounds like the spring on the drive belt is weak or broken needs to be replaced.
9/18/2017 12:36:13 AM • Mtd LAWN MOWER... • Answered on Sep 18, 2017
Mower will not go into drive or reverse White riding mower
bad hdro pump but first try and change hydro oil and filter sometimes it works
5/15/2016 10:34:29 AM • Mtd LAWN MOWER... • Answered on May 15, 2016
2answers
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
12/23/2015 6:09:12 PM • Mtd LAWN MOWER... • Answered on Dec 23, 2015
0answers
Why rider mower wont shut off?
The ignition switch may be broken or have a loose wire.
12/22/2014 7:52:55 AM • Mtd LAWN MOWER... • Answered on Dec 22, 2014
Where is oil drain plug on MTD mower
If it isn't on the bottom of the engine (above the blade) then you don't have one. This is not that uncommon. When you need to drain the oil, FIRST- pull the spark plug wire off!!! Then remove the dip stick or filler plug and turn the unit upside down and drain the oil.
12/22/2014 7:50:40 AM • Mtd LAWN MOWER... • Answered on Dec 22, 2014
I need a diagram for cub cadet 1018 mower deck belt replacement
Contact MTD if your manual doesn't cover this, or buy a shop manual
12/22/2014 7:27:59 AM • Mtd LAWN MOWER... • Answered on Dec 22, 2014
I can't remove the main pulley on the motor
Instead of spending all day banging on it all day and getting frustrated i usually run down to the local auto parts shop and borrow a puller, most places these days has a lending library where you have pay a deposit and once you bring back the tool they will give you your cash back. Best way to make sure it comes off without damaging it out of frustration. use a few squirts of penetrating fluid before you go and it will help as well.
8/12/2014 1:38:27 AM • Mtd LAWN MOWER... • Answered on Aug 12, 2014
5answers
MTD Yard machine Lawn mower. Slips and jerks while
SOUNDS LIKE THE INPUT SHAFT ON THE TRANS IS STRIPED OUT
7/19/2014 4:57:56 PM • Mtd LAWN MOWER... • Answered on Jul 19, 2014
Husqvarna Will not go into gear forward or
check the tension on the drive belts
11/27/2013 10:34:27 PM • Mtd LAWN MOWER... • Answered on Nov 27, 2013
2answers
I am looking for a Shift Cable for my riding mower ,Yard Bug MTD.
I.D. plates are offen found over one of the rear wheels, or under the seat. You may be able to make your own cable, HD/Lowes/hware stores carry cable in bulk and also have clamps to secure a loop in the ends. good luck, Chuck
9/28/2013 6:34:04 PM • Mtd LAWN MOWER... • Answered on Sep 28, 2013
2answers
Clutch pedal on 12.5 mtd only releasing halfway
yes there is a pulley under the tin cover by the forward rev shift control in the center that pulley changes dia when changing speeds they get stuck and don't change position
4/11/2013 1:38:01 AM • Mtd LAWN MOWER... • Answered on Apr 11, 2013
When engaging blades engine dies after mowing over 2in sawn off tree stump
take deck belt of and check that blades stiil turn by hand most likley bent or broken
2/27/2013 1:39:39 PM • Mtd LAWN MOWER... • Answered on Feb 27, 2013
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
113 questions posted
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
42 yard man riding lawn mower need
  • Garden
