20 Most Recent
Remington PowerMower 17-Inch 60-Volt Cordless/Corded Electric Combination Lawn Mower Questions & Answers
I have the Remington Cordless
The Remington battery has 5 Alkaline battery cells. The model batteries are Yuasa NP5-12T, NP 5-12T .250 terminal or Equivalent. It is a very Easy R & R job. Takes about 10 minutes. You should be able to pick up the batteries for around $10 - $15 each.
8/27/2011 12:04:03 AM •
Remington...
Answered
on Aug 27, 2011
I have lost the key
You can do this ,but why take a chance of burning up your mower. You should be able to buy a key for this unit from your local dealer. I believe these keys are all of same cut, like a light switch. this way if you can con someone else into mowing your lawn, they can't say I'm not mechanical and don't know how to jump wires, or worst , see first sentence.I feel this will be the easier way. GOOD LUCK.
6/17/2011 5:48:30 PM •
Remington...
Answered
on Jun 17, 2011
The front right wheel repeatedly comes off because
Can you drill a small hole down through the end of the axle and put a washer and cotter pin to keep the wheels on?
Can you attach a flat piece of plastic or aluminum sheet under the grass catcher to prevent the bag from wearing as it slides along?
Next ....use the best oil you can get......in the engine.......they are also not made as well as they used to be (service life has been reduced ) so take extra good care of it.
9/4/2009 11:31:23 AM •
Remington...
Answered
on Sep 04, 2009
B&D CMM1000 keeps stalling
take out your battery take it to an auto parts store and, have it charged and, load tested with a carbon pile tester this should be a free test
6/23/2009 11:11:43 PM •
Remington...
Answered
on Jun 23, 2009
Remington 4620 fuel line diagram
Check this out https://www.google.com/search?q=Remington+4620+fuel+line+diagram&rlz=1C1ASUM_enPH918PH918&source=lnms&tbm=isch&sa=X&ved=2ahUKEwi1mr7S-s72AhXSsVYBHUBpCcMQ_AUoAXoECAEQAw&biw=1517&bih=736&dpr=0.9
