20 Most Recent
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685 Questions & Answers
I can't find my manual for a Tecumsah LawnBoy 824E
Hi
Sounds like a clogged carb which is a common problem for snowblowers due to they set around more then they get used and gas turns stale and clogs carb. Most of the times the problem is in the bolt that holds the carb bowl on it should have 2 or 3 small holes in it. Check that the holes are all open and clean if this does not help you will need to remove and clean whole carb.
Sam
Please vote
Oil leak
sounds like a bads gasket somewhere on the motor body
