20 Most Recent Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Questions & Answers
Briggs and stratton 44m777 stalls
Replace the fuel lines. I had the same problem with one of my riders. The inside of the fuel lines had rotted and they were collapsing when they tried to suck the gas through them. New lines and it ran all day!
10/15/2023 8:07:41 PM • Briggs &... • Answered on Oct 15, 2023
Briggs & Stratton 26 HP 446777 Twin Cylinder. It is popping and running rough.
Question edited for a lot more clarity and add maker. Question moved from Cars and Trucks. Running lean. Bad Gasoline and clean the carburetor.
10/10/2023 3:34:50 AM • Briggs &... • Answered on Oct 10, 2023
Plug gap 675e series
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi0mN-q5oH9AhVlkYkEHXKoAlsQFnoECBAQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft26697256-plug_gap_675e_series&usg=AOvVaw38_uBSYnpY_8gFFpkWJTgR
2/6/2023 9:06:15 PM • Briggs &... • Answered on Feb 06, 2023
My craftsman 20hp mower ran for 15 minutes with
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiejZiJ5oH9AhXsk4kEHWSSDWYQwqsBegQICBAF&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DA23nERLrBAk&usg=AOvVaw0Np1nZ7kKaEqNAp1FbmueT
2/6/2023 9:05:10 PM • Briggs &... • Answered on Feb 06, 2023
I have a troy built
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjPwu3B5YH9AhVqkYkEHRwKCAIQFnoECAUQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft5979403-troy_built&usg=AOvVaw0b3wiQJvQu7Er6dxxb4OY8
2/6/2023 9:03:25 PM • Briggs &... • Answered on Feb 06, 2023
Blowing oil out of the exhaust 18hp intek oh
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjp1p2k5YH9AhW_jYkEHTR1D_QQwqsBegQIBxAF&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZDVEZ0LkUfc&usg=AOvVaw1rd1buY3OdXZyXvayWD93B
2/6/2023 9:01:24 PM • Briggs &... • Answered on Feb 06, 2023
HOW DO I SET THE CAMSHAFT TO TIME? I HAVE MODEL
https://www.youtube.com/watch?v=yKFAmfeaycs
2/6/2023 8:59:07 PM • Briggs &... • Answered on Feb 06, 2023
I have a Briggs Intek 24 hp twin that only wants
Hi sounds like a carbretta problem, not enough fuel reaching the engine for it to run at higher rev's.
1/19/2023 6:31:51 PM • Briggs &... • Answered on Jan 19, 2023
BRIGGS and STRATTON 18.5 hp V Twin OHV INTEK Engine blows oil out of the fuel pump and the oil is dirty soon after oil change.
Question edited for clarity. Question moved from Hewlett Packard Computers It sounds like you have excessive bore wear and / or broken piston rings and that is causing exhaust gasses to go past the pistons.
10/23/2022 11:28:29 PM • Briggs &... • Answered on Oct 23, 2022
2answers
I have an estate 2005 20hp ohv I/c v-twin model
carb carb carb rebuild rebuild rebuild but as always check spark and compressin on both sides if you only have spark on one side it will sound fine untill under load
8/21/2022 11:48:55 PM • Briggs &... • Answered on Aug 21, 2022
2answers
Carburetor flooding
Not familiar with this model, but this is exactly how the smaller ones behave when the carburetor diaphragm is shot. Larger engines usually have a float system with needle and seat in which case the problem is either a leaking needle/seat assembly or saturated float.
5/4/2022 2:39:28 PM • Briggs &... • Answered on May 04, 2022
2answers
I have a Briggs & Stratton 28S777 15.5 hp. Very hard to start with backfiring. I have checked tappets and flywheel key. When I get it to run it's very smooth..
Question edited for clarity. Question moved to a Briggs and Stratton category. Check ignition timing. Check / replace Spark Plug and check lead condition. Clean carburettor. Lots of help in the videos https://www.google.com/search?q=Briggs+%26+Stratton+28S777+hard+to+start ..
3/30/2022 10:55:39 PM • Briggs &... • Answered on Mar 30, 2022
2answers
How does one increase the engine rpm on a briggs
should be a metering screw for the carb that goes in and out for idle adjust.
6/19/2021 6:33:52 PM • Briggs &... • Answered on Jun 19, 2021
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
10/10/2019 7:15:12 PM • Briggs &... • Answered on Oct 10, 2019
Oil coming from valve cover
did you gap spark plug to.028" ? may need to replace the valve cover gasket.
7/8/2019 8:55:22 PM • Briggs &... • Answered on Jul 08, 2019
The govenor rod cannot be adjusted. The springs
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
5/29/2019 12:00:28 AM • Briggs &... • Answered on May 29, 2019
Getting spark to number one
Did you replace spark plug?
4/30/2019 6:17:06 PM • Briggs &... • Answered on Apr 30, 2019
3answers
My 24 hp intek is only running on one cylinder
Are you sure both magnetos are good? did you try swithing them to see if it reverts to the other cylinder. If that's not it I'd expect a stuck valve,or the adjustment came loose. Take valve cover off and make sure both are moving..
4/30/2019 6:07:52 PM • Briggs &... • Answered on Apr 30, 2019
I have a B&S Intek (446677) with two carburetor jets (one has the number 111 and the other has 114) which jet goes on the left side of the emulsion tube and which jet goes on the right?
i own a shop and i see no one gave you the right answer 114 is the right and 111 is the left come on guys be help full give clear answers for ppl ! hope this helps some one! from second hand diy catch us on youtube!!!
2/2/2019 9:53:41 PM • Briggs &... • Answered on Feb 02, 2019
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,265 questions posted
Top Briggs & Stratton Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Measuring Tools & Sensors
Most Popular Question
oil coming into carberater think vent
  • Measuring Tools & Sensors
