20 Most Recent Robinair Cool Tech 34700Z Recovery, Recycling, Recharging Questions & Answers
2answers
We serviced out 34288 machine
Try with this code-FD32C46B01. I'm sure this will work! Good luck & vote for my solution
11/18/2022 3:46:50 PM • Robinair Cool... • Answered on Nov 18, 2022
I have a 34788 and it keeps leaking through a
With power off, open the filter & check two 'O' ring of filter is in the right position then replace filter again. Hope this will solve your problem.
9/13/2022 8:24:27 PM • Robinair Cool... • Answered on Sep 13, 2022
3answers
Robinair Cool-Tech 34700z sending refrigerant to oil recovery container when charging system.
You confirm it by how it functions, if it sticks in a mechanical way there is no electrical testing that would be valid. I would just replace both solenoids.
8/29/2022 12:50:18 AM • Robinair Cool... • Answered on Aug 29, 2022
2answers
Robinair 34700 hi-p
Disconnected Air Purge lines. It was under high pressure (careful).
7/2/2022 9:41:06 PM • Robinair Cool... • Answered on Jul 02, 2022
How do you calibrate a new internal scale in a
From the main menu go to change default option,press 5454 then press enter key.after access to default nenu you have to select calibrate scal option.press again enter key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop key to complete the prcess.
4/5/2022 11:41:28 PM • Robinair Cool... • Answered on Apr 05, 2022
4answers
Is there a new 10 digit code for replacing filter on robinair 34788? I try the old two codes that Mr. Hasan Khan Amran posted but fail please post another code . God bless you
Please be informed that, one code can be use only one time! However now i will give one more new code: 6FAAC95001. Apply it now and solve the problem! Don't forget to vote for it, if you wish to get help in future. Good luck....
7/1/2021 2:26:30 PM • Robinair Cool... • Answered on Jul 01, 2021
2answers
I have a robinair 34788 and when i tunr it on it
This is a common problem of Model: 34788, 34788-I, 34988, AC34788, GE48800 etc. You need to replace air purge solenoid (Air purge solenoid located on top of the ISV tank, if you open front panel cover then you can see it on top of the tank). After doing above stapes and your problem still exist then you have to replace PCB relay board. Hope this will solve your problem, if so please vote for it for farther help! Good luck
3/5/2021 11:19:03 PM • Robinair Cool... • Answered on Mar 05, 2021
2answers
Robinair 34700z displays toggle input, input 0
You can try 1# With power on press and hold for 4/5 sec. up & down arrow key at the same time
2#With the power on press YES/START & NO/STOP key at the same time
11/8/2020 1:21:41 AM • Robinair Cool... • Answered on Nov 08, 2020
On pulling a vacuum the
Check oil drain solenoid for any debris or damage inside the solenoid flunger. Replace/rebuild as needed. Hope this will solve your problem. Don't forget to vote for my solution
6/11/2019 6:58:26 PM • Robinair Cool... • Answered on Jun 11, 2019
Hello,my Robinair 17800b is stuck in he Clr mode,can someone help me?
If you have less than 10lbs of refrigerant in the tank and you're changing modes, this can happen. If this is the case, Tech Support can help walk you through a reset process at 800.822.5561
1/29/2019 12:45:45 AM • Robinair Cool... • Answered on Jan 29, 2019
I have a robinair a/c machine cooltech i need to
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen text.Hope this will solve your problem.
NOTE:you should have 9KG/20LBS of weight for scale calibra
2/15/2018 6:49:18 PM • Robinair Cool... • Answered on Feb 15, 2018
I have a robinair 34700zasking me if i wanna
You have run the machine 10+ hours for vacuum since last oil change. so you have to change vacuum pump oil. For change vacuum pump oil just follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL'' then press "YES" key. Now vacuum pmp will run for two minute & stop automaticly. When pump stop you just open the oil drain plug & oil fill cap of vacuum pump ( Located oute side of the machine near high & low side hose ) & drain all oil from vacuum pump. After draining used oil,replace oil drain plug & fill new ROBINAIR vacuum pump oil till middel of sight glass.Press "YES" key & follow on screen messeage. NOTE: Do not over fill the pump & Do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support.
8/15/2017 2:39:41 AM • Robinair Cool... • Answered on Aug 15, 2017
Machine won't recover, it gets stuck on "clearing in progress" Also won't vacuum, it says that "pressure exist press any key to continue" Your help would be greatly appreciated
I had a similar problem with a Robinair 17800b. The machine got stuck in Clr or (Clearing) while changing from R-12 to R-134a. If the tank (R-12 or R134a) does not have at least 10 pounds of refrigerant in the tank before you change to another refrigerant, the machine will stay in the clearing process. I called tech support and they walked me through a process that resets the machine. The reset involves entering a code while in r-12 mode, then removing all hoses and switching the switch to R-134a mode and entering another code. The call to the tech line took about 5 mins. The number I called 1-800-822-5561.
7/24/2017 4:52:04 PM • Robinair Cool... • Answered on Jul 24, 2017
Robinair 34788 will not charge properly
I would be very careful releasing refrigerant from the liquid side of the tank as suggested earlier. Knowingly releasing R134 into the atmosphere carries very large fines if you get caught and is very environmentally irresponsible.
7/9/2017 12:35:18 AM • Robinair Cool... • Answered on Jul 09, 2017
I have a 34711-2K and
Phone the agents for the answer.
6/7/2017 10:44:59 AM • Robinair Cool... • Answered on Jun 07, 2017
2answers
I have robin air 34788.
6/2/2017 2:09:10 PM • Robinair Cool... • Answered on Jun 02, 2017
Machine says pressure exist unable to vacuum
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
11/17/2016 6:26:03 PM • Robinair Cool... • Answered on Nov 17, 2016
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
367 questions posted
Top Robinair Measuring Tools & Sensors Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Robinair Measuring Tools & Sensors
Most Popular Question
  • Measuring Tools & Sensors
