20 Most Recent Proform 860 Competitor Treadmill Questions & Answers
0answers
I have to adjust my belt every time I get on it. What could be causing this please?
LUBE the deck belt and rollers bearing and adjust the slipping see the video. If the problem persist is TIME to replace the old board deck belt.God bless you
3/6/2013 10:06:11 PM • Proform 860... • Answered on Mar 06, 2013
Proform 860 runs at top speed even when safety switch is out
Run the software calibration for easy troubleshooting and fix it. God bless youCalibration for "Newer Style" Consoles
The Calibration sequence can generally be used to accomplish the following: 1) To reset the treadmill's speed software, if the running belt seems to be moving faster or slower than the speed indicated on the console. 2) To reset the treadmill's incline software, if the walking deck seems to be elevated higher or lower than the height indicated on the console. 3) To synchronize the treadmill's electronic package ANY TIME a replacement part (anything electrical) has been installed and is being prepared for use. 4) This should be the first step performed when attempting to diagnose or troubleshoot the unit.Calibration often helps in correcting minor "bugs" in the software (by "resetting"), before actually having to replace components.
Before You Begin:
You must first determine the model number and style of unit of the unit being worked on. Do this by:
  • Powering up the treadmill and removing the emergency stop key (usually a magnetic plastic piece that attaches to the top, center of the console). If you see "10" in the console, it is an old style console and the "Older Style" Calibration should be referenced. If an "SI-1" appears in the console, it is a newer console. The following calibration sequence can be performed.
Note: To change any of the current codes (if incorrect or out of sync), use the SPEED + or SPEED -(minus) button(s).
Refer to the Calibration Chart (or the unit's owner's manual if not on the chart) to verify that the calibration codes on the unit (represented as "??" below) are correct.
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
2/8/2013 10:59:56 AM • Proform 860... • Answered on Feb 08, 2013
Treadmill is stuck in fastest position and will not change
1) LUBe the elevation motor, in shaft and gear2) adjust the small POTentiomenter for to liberate the elevation motor3) clean the relais contacts, and tight every connector.see the diagram and fix it.God bless you1_18_2013_6_55_30_pm.jpg1_18_2013_6_56_07_pm.jpg
1/18/2013 6:56:21 PM • Proform 860... • Answered on Jan 18, 2013
Proform 860 competitor motor wont run
Lube the deck belt with 100% siicone or wax2) Lube the rollers bearing3)test tbe drive belt for worn4) Test the input voltge motor, if there are the motor need repair, see my personal TIPS for motor help5) Test the the output board, for input voltage motor if there are Not the board is faulty.God bless you12_5_2012_9_21_46_pm.gif
12/5/2012 9:22:13 PM • Proform 860... • Answered on Dec 05, 2012
Power is on, motor doesnt run
1)Lube the deck belt with 100% silicones or wax follow the instr. manual2) Lube the rollers bearing with wd-403) Test the drive belt motor,for worn and replace if necessary4) Test the input voltage motor, if there are the motor need repair.5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty..God bless you12_5_2012_9_18_12_pm.gif
12/5/2012 9:18:17 PM • Proform 860... • Answered on Dec 05, 2012
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.God bless you
5/17/2012 5:00:05 AM • Proform 860... • Answered on May 17, 2012
0answers
0answers
I walk at 4.7 on
The walking deck needs lubricated if it continues after lubricating replace the controller
8/10/2010 8:47:43 PM • Proform 860... • Answered on Aug 10, 2010
I need to tighten the belt, it keeps slipping while walking on it
Unplug unit then remove motor shroud then do the following: If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
1) Adjusting the running belt if the problem: If the walking belt slips when walked on, UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
2) Adjusting Drive belt: Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
5/15/2010 5:29:38 PM • Proform 860... • Answered on May 15, 2010
A transformer on my 29958 proform 860 qt tends to
using my tread on level 3 for 30 minutes and it shut off at 25 minutes what this?
4/11/2010 5:40:31 PM • Proform 860... • Answered on Apr 11, 2010
My proform 860 has belt slippage and sometimes
I had the same problem and was about to change the walking belt. Instead I removed the 5 screws holding on the hood and adjusted the Reed Switch and took a walk. Whenever I stomped on the belt hard it would stop. I Could now see (because I removed the hood) that the motor continued to spin and the Motor Drive Belt was slipping and was the culprit. Something that I had noticed before was all this fine rubber dust coming out near the left front corner where this belt is. If you see that it's a good indicator the motor belt is slipping and needs to be replaced.
1/10/2010 9:52:35 PM • Proform 860... • Answered on Jan 10, 2010
I got my ProForm 860 treadmill and the previous
Be sure there is no damage to the walk board itself before replacing the belt. You may want to try lubricating the board before replacing the belt.(silicone spray from any hardware store) This is also caused by overtightening of the drive belt and/or walk belt. Good Luck, Tim
11/13/2009 2:03:52 AM • Proform 860... • Answered on Nov 13, 2009
Proform 860 treadmill incline is stuck in full incline position
With the key inserted in the console, press one of the Incline buttons. While the incline is changing, remove the key. After a few seconds, re-insert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. This will recalibrate the incline.
As for the speed led. the +12v means that there is a unstable current that is detected. this can because of a corroded wire connector or an failing capacitor wish in the power control board.
4/19/2009 6:24:11 PM • Proform 860... • Answered on Apr 19, 2009
Proform crosswalk caliber elite cuts off after 10 minutes of use
Here are some possible causes and solutions: Overheating: If the motor or electronics of the treadmill get too hot, the machine may shut down to prevent damage. Make sure that the treadmill is placed in a well-ventilated area and that the air filters are clean. You can also try lubricating the walking belt to reduce friction. Faulty speed sensor: If the speed sensor is malfunctioning, it may cause the treadmill to shut down. You can try cleaning the speed sensor with a soft cloth and see if that helps . Worn walking belt: If the walking belt is worn or damaged, it may cause the treadmill to shut down. You can try replacing the walking belt and see if that helps. Electrical issues: If there are any electrical issues with the treadmill, it may cause the machine to shut down. You can try resetting the circuit breaker or unplugging the treadmill for a few minutes and then plugging it back in. If none of these solutions work, it may be best to contact Proform customer service.
1/20/2024 8:51:12 AM • Proform Exercise... • Answered on Jan 20, 2024
Proform 400R Exercise Bike. How to install seat handle please? Having trouble with seat adjustment handle.
Question edited for clarity. Here is the manual with assembly instructions starting on page 5.
ProForm XP400 R User Manual
ManualsLib https://www.manualslib.com > ... > XP400 R View and Download ProForm XP400 R user manual online. 831.217520. XP400 R exercise bike pdf manual download. Also for: 831.217520. ..
12/31/2023 11:40:25 PM • Proform Exercise... • Answered on Dec 31, 2023
Proform Crosswalk Treadmill. Where can we buy a motor controller, part number 101757?
Question edited for clarity. Try contacting Treadmill doctor direct.. They have the best spares collection. https://www.google.com/search?q=Proform+Crosswalk+Treadmill.+motor+controller%2C+part+number+101757 ..
9/30/2023 4:11:42 AM • Proform Exercise... • Answered on Sep 30, 2023
Proform 860 Competitor Treadmill Logo
19 questions posted
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
adjust belt every time get could
  • Exercise & Fitness
