20 Most Recent Proform Crosswalk 500 Treadmill Questions & Answers
My Proform Crosswalk 395 Treadmill will turn on but belt does not. We just moved it from the garage into the house.
Question edited for maker name. Question moved from Building Materials to a Proform Crosswalk category. Either the belt is too slack or it needs to be reset. https://www.manualslib.com/manual/672296/Pro-Form-Crosswalk-395.html?page=20&term=reset&selected=9#manual ..
2/1/2022 6:24:38 PM • Proform... • Answered on Feb 01, 2022
On low speed the treadmill
For a repair person near you, see the directory at Treadmill Repair Directory
6/25/2020 5:55:35 PM • Proform... • Answered on Jun 25, 2020
3answers
How to replace a running belt on a Technogym
USE THE PATIENCE, CAREFULLY, AND BASICS TOOLS.
Watch this Video:
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
Friction is the #1 cause of this problem. Many cheaper treadmills have amotor with a cardboard core (people wonder why we are so down on cheap treadmills) and if the voltage and amperage through themotor heats it up sufficiently, it begins to smolder. If this is the case, you normally have to replace the belt and the motor and inspectthe deck. If the armature has cooked enough in the motor, you also have to replace the motor. If the belt and deck check out OK, check for a short in the motor. Youcan run the motor with an independent power source like a fullycharged cordless drill battery to see if the symptoms are the same. Click on thefollowing link for our motor test. If the belt and deck check out and the motor is OK, then check yourwiring and electronics for signs of scorching and replace the appropriate part(s).
Sincerely. God bless you.
If you need further assistance, please reach me.
6/24/2020 7:44:49 PM • Proform... • Answered on Jun 24, 2020
8answers
Problems with my pro form 540 treadmill
So after reading the post from EricLaw, I wanted to clarify his solution because it also worked for me. When you open up the console, you will see the membrane (it actually says membrane inside very small) and the connecting wires to the membrane is actually a wide flat plastic with some stripes embedded in the clear plastic which can be easily detached from the membrane (looks like masking tape w/ stripes). These stripes are how the touch pad on the console talk to the membrane. I then took scissors and cut slits between each stripe (cutting only the clear plastic part of the plastic tape) so that I could leave a strip out of the membrane. I played around leaving different strips out until the right strip was left out. If I recall correctly, I left the 5th strip out and the key pad now works entirely EXCEPT the speed 1 and 4 which were the only keys working until I did this. Hope this helps.
4/29/2018 2:04:28 PM • Proform... • Answered on Apr 29, 2018
I have a PROFORM CX 500 at my home. It used to
You must LUBE the roller bearing front and back with WD-40 very well. . 2) Examine the drive belt motor, if are very tight, must be deflection 1/8" other wise the ball bearing of motor are very tight.Tight very well the bolt of motor. 3) Run again, if the problem persist, the Rollers are Faulty. Replace. Treadmill Repair worn belt roller bearings Blessing. [email protected] cell+whatsAPP:+50588611441
11/26/2017 2:48:00 PM • Proform... • Answered on Nov 26, 2017
Technogym run 500 blocked
Dear Sir, if you need further help please contact our local customer care: [email protected]. They'll be very happy to help you. Technogym Headquarter
11/17/2017 7:57:06 PM • Proform... • Answered on Nov 17, 2017
Have a PROFORM CX 500
1)Examine, the board or Running deck, if the holes where the screwdriver are Looses, TIGHT very well, and see if there are doing correct . Normally this happen when the person training is Jumping, Is NOT normally doing this. Since this machine ARE not Heavy duty like as the machine GYM. Repair or Replace. 2) As a TIP LUBe the bearing Rollers front and back with WD-40 Blessing. [email protected] cell+whatsAPP:+50588611441
11/3/2017 4:14:55 PM • Proform... • Answered on Nov 03, 2017
Proform 500i not working.
Try putting the treadmil in a cooler location. the heat is effecting the mother board.
7/26/2017 10:22:06 PM • Proform... • Answered on Jul 26, 2017
2answers
I have a problem with
just change the Diodes D4015L and SCR´s S4015L whit a caugting buy the new change and ready or is a MC-2100 w / transformer just change the MOSFET IRF250N
10/29/2016 8:46:35 AM • Proform... • Answered on Oct 29, 2016
2answers
Motor runs for a second or two on proform 550e, then stops
Speed sensor.
10/18/2016 11:14:29 AM • Proform... • Answered on Oct 18, 2016
Why does the belt keep veering left?
It should be an adjustment of the roller.
7/20/2015 1:45:18 AM • Proform... • Answered on Jul 20, 2015
2answers
What's your problem?How to change a running
Dear Sir:
I will try to help you, use the patience, carefully and basic tools.
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
If you need further assistance, please reach me, sincerely. God bless you.
with this you must fix it.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
5/28/2015 10:12:17 AM • Proform... • Answered on May 28, 2015
2answers
I have an pro form trademills showing an E1 error
motor brushes are bad that is why motor can not start itself
12/8/2014 10:29:43 PM • Proform... • Answered on Dec 08, 2014
Proform Crosswalk 500 Treadmill Logo
229 questions posted
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
mc 2000 es
  • Exercise & Fitness
