20 Most Recent
Landice L7 LTD Executive Trainer Treadmill Questions & Answers
Reset incline
Run the software calibration for easy diagnostic and fix it. God bless you
Factory reset code
follow this instruction and reset. God bless you Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen. 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset. Read more:
http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
When I turn on I get an overspeed error and
Your speed sensor is not working properly this part is located under the motor shroud and on top of drive motor it is attached to a bracket with 2 bolts.
Unplug the unit and remove motor shroud see if you can adjust it first by loosen the 2 nuts and moving the sensor forward without making contact to the flywheel, then tightened the nuts up.
Plug the unit into the outlet, start the unit, if you still have the overspeed then replacement of the sensor is needed. Call Landice Directly they will ask for model and serial number and they will the new sensor.
My Landice L7 treadmill for home use races to speed when I turn it on. I cannot control the speed, it just increases automatically to top speed.
There could be a few different things causing your Landice L7 treadmill to race to top speed when turned on. Here are some potential causes and solutions:
- Motor Control Board: The motor control board may be malfunctioning and sending the treadmill into top speed automatically. If this is the case, you will need to replace the motor control board.
- Console Board: The console board may be sending incorrect signals to the motor control board, causing the treadmill to race to top speed. If this is the case, you will need to replace the console board.
- Speed Sensor: The speed sensor may be malfunctioning and sending incorrect signals to the motor control board. If this is the case, you will need to replace the speed sensor.
- Calibration: The treadmill may be out of calibration, causing it to race to top speed. To recalibrate the treadmill, consult your owner's manual for instructions.
It's recommended to consult with a qualified technician to diagnose and fix the issue to avoid causing further damage or injury.
