20 Most Recent
RTO Sole F80 Treadmill Questions & Answers
Motor is not responsive and it read LOW SPEED message and time L51
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Make sure the console cable is not pinched or damaged in any way.
Turn the power off, unplug the power cable and wait 60 seconds. Remove the motor cover. Wait until all red LED lights have gone off on the motor control board before proceeding. Next, verify that none of the wires connected to the lower board are loose or disconnected.
When I turn on and select start, it powers down as it trips the house circuit. Why is this happening, it has never before?
Could be that there is a short in your wall outlet, you can try switching the treadmills power cord to a different outlet.
You always want to make sure that your treadmill is on a dedicated circuit.
You also might want to try and just reset the power switch, leaving it off for 5 minutes and switching it back.
It could also be that one of the electric components on the main board, for example like a capacitor is damaged which in turn is causing the unit to draw "too much" voltage into the machine.
If switching outlets does not do the trick, you can remove the main shroud and inspect that main board, check any wires for crimping and or any components that look damaged.
If not any, with the shroud off you can turn the machine on. Just check to see if the main control boards LED's come on.
You will most likely get LED's since you said it turns on, then off when you hit start.
If you find you need any further assistance, we would be happy to help you :) by chat at
www.sportsmith.net or by phone at 888-713-2880
We look forward to hearing from you!
How do you "run the software calibration"?
- Turn unit on
- Pull out the safety key
- While holding down the 'start' and 'speed increase' button insert the safety key. Unis should now say calibration.
- Press enter on all options until screen does not change when you press.
- Press 'Start' (Unit will run auto calibration). If passed, the unit will reset itself. If fail it will say 'fail'.
- If you do not see 'fail' power off, then on again once done.
- You're good to go. (If unit says 'fail' contact service)
Techmotion Corp does service and repair in many north-east states.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Low speed fault
With belt movement check speed sensor. Without belt movement check MCB. If you neglected unit it could be belt and deck if its shutting down during a workout. I have also see a lot of on/ off switches getting old and causing LS errors due to low voltage to MCB
