20 Most Recent
Precor EFX 546i Elliptical Version 4 Questions & Answers
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion
Probable Cause
1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
- Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
- Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
- If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals
This
notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the
warning about the
battery installation for certain models of the
Precor ellipticals.
Precor Elliptical Models Affected:
- EFX C524 with serial#s beginning I7, K7, LH, SW, SX
- EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
- EFX C546I with serial#s beginning X8, XG, Z2
- EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the
EFX C524, EFX
C546, EFX C546i and
EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
How do I replace the battery on efx 546i
This
warning about the
Precor ellipticals.
EFX C524, EFX
C546, EFX C546i and
I want to replace the battery
This
warning about the
Precor ellipticals.
EFX C524, EFX
C546, EFX C546i and
