20 Most Recent Lenovo IdeaPad Z500 Laptop Computer - 593126U - Dark Chocolate Questions & Answers
When I update Windows 8 to 8.1 Lenovo Z500 Series Laptop than My computer Brightness is decrease.
Try this: https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Z400-Adjusting-the-Brightness-in-Windows-8-1/ta-p/1303113
7/13/2015 2:53:33 AM • Lenovo IdeaPad... • Answered on Jul 13, 2015
3answers
My lenovo z500 has a screen brightness issue. It very dim and it won't turn up no matter what I do?
Hi, I had this problem also and I don't know why, but Lenovo Ideapad Z500 seems to have some compatibilities issues with a new Intel video card.So, what you need to do is rolling back the HD intel video card driver to the previous version OR go to the following path: D:\drivers\VGA\Intel\x64\9.17.10 and press Setup to install the old driver again.That solved my problem. It's a shame that I can't upload this driver in my laptop.
4/11/2015 2:19:40 PM • Lenovo IdeaPad... • Answered on Apr 11, 2015
I have a problem with microsoft office 2013 it asks product key i cannot find it it was given at the time i brought the ideapad z500 laptop
You can get an Microsoft Office product key from ### Windows 8.1 key sale *** , it works very simple and fine,you need to search for it from bing.
3/20/2015 10:08:15 AM • Lenovo IdeaPad... • Answered on Mar 20, 2015
Brightness issue
Hi! Try not to use anything wet next time, just special tissues with soft chemicals only. And keep laptop switched off while you clean it! Do following:
  1. Get notebook to service, or next steps:
  2. Download service manual from the internet;
  3. Unscrew two keyboard bolts;
  4. Push tiny screw driver in those two holes;
  5. DO NOT DETACH keyboard immediately, just turn it slowly untill you can see wiring;
  6. check if surfaces on and under the keyboard are clear and dry;
  7. find keyboard wiring;
  8. detach it carefully;
  9. dry the laptop;
  10. check connection and put small wires back again...
Have fun if it is working. If not - change the keyboard.
3/12/2015 4:25:47 PM • Lenovo IdeaPad... • Answered on Mar 12, 2015
Keyboard connector motherboard broken
The only option is left connect a usb keyboard or use a wireless keyboard.
2/7/2014 8:52:12 AM • Lenovo IdeaPad... • Answered on Feb 07, 2014
After upgrading to windows 8.1 my laptop is taking
You need to find out what is lagging. Try http://msdn.microsoft.com/en-us/library/hh162945.aspx this will show you the culprit!
10/31/2013 9:03:33 AM • Lenovo IdeaPad... • Answered on Oct 31, 2013
Camera problem! I've installed driver but i cant
what operating system is installed on your laptop?
8/9/2013 9:40:07 AM • Lenovo IdeaPad... • Answered on Aug 09, 2013
Screen suddenly dimmed, will not get brighter
Your LCD screen is dying. The backlights can go over time. Other then try to replace the screen there is not much you can do. You can always run it off an external monitor if you are like most people and use it a desk most of the time anyhow.
1/12/2013 3:43:20 AM • Lenovo IdeaPad... • Answered on Jan 12, 2013
3answers
My Lenovo IdeaPad G560 turns on, but has only black screen, what should I do?
here it is, youtube, 1pm seen here, see blue coded soldered down ML1220 coin cell your CMOS NVRAM battery is there. https://youtu.be/z1EjNOEy6Do?t=268 just above CPU brace left top screw. BI NGO this one model, of may submodels. the life span is 5 years, but never parked for 7y ever. parking it allows it to go OVER discharged, and now dead faster. if not there you are in a different country.
5/4/2022 1:22:11 PM • Lenovo IdeaPad... • Answered on May 04, 2022
4answers
HOW TO EJECT A DISC IN LENOVO IDEAPAD 330
The CD/DVD drive may be opened by pressing a button on the drive itself. If the drive does not open by pressing a button on the drive itself, or the button is not available on the drive, Windows natively provides the ability to eject the tray with simple methods that can be performed in the File Explorer. The steps vary from different operating systems:
  • Windows 7
  • Windows 10
Note:
  • Not all systems come with a CD-ROM, CD-RW, or DVD drive installed internally to the computer
    • To verify that, you can check the left and right side of your machine. See if there is any slot to insert your CD/DVD. Normally, there is a button to eject the CD or DVD tray for you to insert a disc
    • Another method to identify this is as below: 1. Click Start and type Device Manager in the search box. Select Device Manager 2. In Device Manager look for DVD/CD -ROM Drives If you don"t see DVD/CD -ROM Drives this means your device has no optical drive hardware. An external optical drive will need to be purchased to run CD/DVD. It is also wise to check your product specification to see if your device has an optical drive. If you were previously able to play CD/DVD and DVD/CD -ROM Drives has disappeared from device manager or your device is not reading the disc please follow > Your CD or DVD drive is not recognized by Windows or other programs.
  • The format capabilities of the drive are listed on the label on the external cover of the drive
  • The CD-ROM, CD-RW, or DVD drive can be opened using the emergency eject hole (Bend away a leg of a paperclip to work with. Insert the paperclip slowly until there is resistance, then gently push until the drive door is opened) Applicable Brands
    • ThinkPad
    • IdeaPad
    Solution ·Windows 10 ·Windows 7 Eject disk tray with File Explorer
    1. Turn off all applications currently using the drive. Otherwise Windows will prevent you from ejecting the DVD tray
    2. Hold Windows + E on the keyboard to open File Explorer
    3. Click the DVD drive icon and click the "Eject" button on the toolbar or right-click on the optical drive and choose Eject from the menu that pops up or down.
4/27/2021 1:51:55 PM • Lenovo IdeaPad... • Answered on Apr 27, 2021
Lenovo ideapad s145 my Screen turns white and does nothing after entering phone number during setup
If you bought the Lenovo at a local dealer, take it back to them. If you bought it through an online dealer, I recommend you track down Lenovo customer support.
9/5/2019 6:29:58 PM • Lenovo IdeaPad... • Answered on Sep 05, 2019
Win 10 lenvo ideapad 320 will not play mygames now
really why not ask the game maker directly for help with your w10. here they are right>? https://www.mygames.com/ so what do THEY say , it is there code, running. does Tetris fail or just your games, unnamed, this maker is bad company they take over your PC why run this crappp? it takes over your browser, and more, and is bad. the do not even have minimum system requirement there. nor support. avoid like the Plague.
6/30/2019 1:32:19 PM • Lenovo IdeaPad... • Answered on Jun 30, 2019
I have error C0000034 applying update operation 460 of 41831 (generalize XML). All I did was turn my idea pad on. It never resolves and I have tried turning my laptop off and restarting. Any ideas
Restart your computer & start tapping f/8 immediately and keep tapping until black screen comes up. Use the arrow keys to select safe mode the press enter. It will start up in safe mode in each corner, the icons are all out of shape and a help window will open. Close that window. Then go to: Start, Accessories, System Tools, right click System Restore & send to desk top.(The reason to do that will be to use it easier ANYTIME you have a problem.) Then do a system restore back to a time before you had the problem. That should resolve it. If not you will have to do a Recovery after saving everything you want to keep on a Flash Drive. On start, type recovery & go there & follow directions. I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
4/16/2019 6:12:01 PM • Lenovo IdeaPad... • Answered on Apr 16, 2019
When I flip my screen whilst watching a video on
It's a mechanical problem with the wiring and contacts along the edge of the screen. No "fix" except screen replacement.
4/1/2019 2:16:47 AM • Lenovo IdeaPad... • Answered on Apr 01, 2019
Lenovo IdeaPad Z500 Laptop Computer - 593126U - Dark Chocolate Logo
35 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
lenovo z500 screen brightness issue
  • Computers & Internet
