Dear Sir:I can send to the web page for you contact service repair:http://fitness.manualsonline.com + www.treadmilldoctor.comsince that i can not arrive, because I AM live in Managua, Nicaragua.sincerely. God bless you.E.CUADRAMANAGUA, NICARAGUA. C.A
These units only have a calibration mode. The High end units generally will have that. If this is a Epic Then this calibration procedure should work.
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a movable center and is located near the three small speed wire connections
labeled H, W, & L and is on the same edge of the board and the red and black motor wires are located. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
yes please read your instr manual and see the assembly instr and proceed according in reverse sense.if you do not have the instr. manual go to www.fitness.manualsonline.comGod bless you
Yes please see your instr. manual and follow the steps how to assembling and disassembling. if you do not have download for freefrom www. fitness.manualsonline.com God bless you
1. Hold the upper end of the treadmill with your right handas shown. Using your left hand, pull the latch knob to theleft and hold it. Pivot the treadmill down until the frame ispast the latch pin. Slowly release the latch knobI will strong that you see your owner manual. If you do not have manual.here is the web page for you download free right now:http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=EPTL88105&modelName=EPIC+425+MX+sincerely.Good luck.
you must have a Lamp for to help the screws. Unless the machine had not screws, must be adjusted to a pressure. You must use the screwdriver for to help to open the hood.see the video:
try to RUN the software calibration for diagnose, troubleshooting, fix it.2) LUBE THE deck belt , this happen because the lack of maintenance schedule, maybe the deck is worn and need replace it. see the video and picture3) lube the rollers bearing too very well.4) test the input voltage motor, if there are the motor NEED repair,tight any wires connector for loose5)measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. use the DVOM OR VOM in both cases.see the block d, tight any wires connector or wires loosesGod bless you
Dear Sir:This problem is frequently.1) Check the breaker from your home and reset.2)Inspect the wires from your outlet in the wall and tight it.3)Do not use any extension cord!4)Examine the power cord and see if some wires is loose and tight it.5)Test the ground from your outlet wall, and fix it.6)Reset the c. breaker internal from the treadmill.7) Inspect any wires loose and tight it.8)Lubricates the treadmill between deck vs walk belt, this can cause to shut down the treadmill, since the complex electronic is designed for to protect the electronic components.9) Lubricate the treadmill in according with your manual instructions.10) The ball bearing from motor can be faulty+ball bearing from roller deck.11) The main motor board can be faulty. ( this is last step) sincerely. God bless you.ernesto cuadramanagua, nicaragua.
