20 Most Recent
Epson Expression XP-305 Inkjet Multifunction Printer - Colour - Photo/ Questions & Answers
Epson Scan won't connect to PC
Make sure the printer has power and is turned on. Use the settings box (Control panel) on your PC click on printers and scan for printers. It should find the Epsom. Change setting to make this the default printer. Sorry but that's all I can help you with. Also make sure that the USB has been put in the correct socket on your PC, although I suppose it should work on any USB socket.
Driver software
Just google for your local Epson support site. Use their search function to find your printer and there should be driver files you can download with instructions.
Line across docs where the ink has missed
clean your printhead. it has a partial plug. you can run some cleaning cycles or make a cleaner cartridge. this involves drilling the cartridge and taking a syringe and putting about a full syringe of windex into it and sealing it with hot wax and then putting it into the printer and running cleaning cycles, or taking a small plastic hose on a syringe and putting a pool of windex on the ink pads where the printhead comes to rest and turning the printer off and let it sit for a few hours. it will try to suck the windex out into the waste ink pads so you have to get it there just as it parks. it will let the printhead sit in the windex and wick up into it to unclog it. I’m happy to help further over the phone at
https://www.6ya.com/expert/troy_d840d2702258460c
How to change font size
You need to select the font style or size in the application you are printing from, not in the printer driver.
