20 Most Recent Maytag Legacy MAV208DAWW Top Load Washer Questions & Answers
My Maytag mav208daww won't hold water.
Sounds like a hose has come loose.
9/14/2017 1:56:03 AM • Maytag Legacy... • Answered on Sep 14, 2017
My maytag mav208daww won't spin in the spin
Check for stretched belt causing the issue and the stink. Go here for parts Search Over 2 1 Million Appliance Parts
9/10/2017 1:55:34 PM • Maytag Legacy... • Answered on Sep 10, 2017
I have a Maytag washer model MAV298DAWW. My clothes are still wet after it spins, and it makes a clunk/screech noise at the end of the spin cycle
It could be the clutch if you change it out be very careful. When you remove the cover screws that brake spring hold 500 pound of tension and it will knock your block off.
4/3/2016 9:43:04 AM • Maytag Legacy... • Answered on Apr 03, 2016
Getting lint and scaly deposit on sides of tub even after several cleaning cycles. why?
Check that your water conditioner is working and removing hard ions from your water. Also the scaling you are seeing is likely solidified to the tub surface and needs a more abrasive cleaning method, like a brush with stiff bristles, or even steel wool. Chances were that the water level was high enough for some time to allow the scaling to build up and solidify and thicken to the point where it cannot dissolve with detergents or other chemicals.
1/30/2015 4:07:58 AM • Maytag Legacy... • Answered on Jan 30, 2015
0answers
0answers
Reads error 420KEB OC
Check the washing drum. If it is clean, inside AND outside, time for the trash
6/10/2013 8:30:25 PM • Maytag Legacy... • Answered on Jun 10, 2013
How to remove front panel
there is yubtub that will show you but it is easy.take a putty knife.in front where the sem there are two tabs one on each end find them take the putty knife and push in
2/22/2013 8:44:04 PM • Maytag Legacy... • Answered on Feb 22, 2013
SPINS BUT SOAK CLOTHES
The solution was given earlier.Thank you
2/12/2013 11:51:37 AM • Maytag Legacy... • Answered on Feb 12, 2013
During spin its unbalanced
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
2/12/2013 11:16:32 AM • Maytag Legacy... • Answered on Feb 12, 2013
Maytag washing machine no water coming in
check water coming out of hoses. check on hot and cold fill. could be fill valve
2/9/2013 10:41:05 PM • Maytag Legacy... • Answered on Feb 09, 2013
Agitator makes noise
Pop the the fabric dispenser off and make sure the agitator bolt is tight.
10/21/2012 6:18:48 PM • Maytag Legacy... • Answered on Oct 21, 2012
Maytag Legacy MAV208DAWW Top Load Washer Logo
85 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
washer will not spin fast also notice
  • Washing Machines
