20 Most Recent Ericsson SCREEN PROTECTOR MEXXPROTECT Crystal-Clear for Sony W595i, W-595i, 100% fits, Display Prote... Cell Phone Questions & Answers
Restart problem in w595 phone (Restart in several min)
How to choose your next smartphone?
  1. Consider the operating system whether it's iOS, Android, or Windows.
  2. Look into the phone's specifications to determine which suits your needs best.
  3. Filter your choices through the phone's features and choose what's useful for you.
  4. Determine which of your options fits best in your budget range.
Read more here for to learn the details of each of the above considerations : 4 Effective Tips on How to Choose Your Next Smartphone
11/10/2017 1:48:59 PM • Ericsson SCREEN... • Answered on Nov 10, 2017
3answers
Remove air bubbles from cell phone screen saver
Peel off or otherwise remove the screen protector, spray the adhesive (sticky side) with glass cleaner, then reapply the protector and use a credit card to roll out the air bubbles.
11/21/2014 4:10:13 AM • Ericsson SCREEN... • Answered on Nov 21, 2014
How to apply screen protector?
The screen should be cleaned thoroughly with an alcohol pad leaving no lint/dust. Then peel the back of protection screen off halfway, line up the peeled part on screen to your liking then use a credit card to push towards the end you haven't peeled yet while pulling the remaining backing and pushing the credit card from middle to edges.
8/31/2014 5:54:06 AM • Ericsson SCREEN... • Answered on Aug 31, 2014
2answers
I want to format my memory card ....my mobile is
the below codes will help you to solve this0000 or 1234 or 12345 or 00000000 or 12345678
10/1/2013 12:10:11 PM • Ericsson SCREEN... • Answered on Oct 01, 2013
3answers
HOW TO FIND THE PUK CODE FOR MY MOBILE PHONE
PUK code is a code provided by the service provider. Call up the Customers Services of your service provider.
5/13/2012 8:46:40 PM • Ericsson SCREEN... • Answered on May 13, 2012
2answers
Walk mate does not work
you need the GPS headphones (sold seperately) to be attached. Then walk..... it will count your footsteps...
5/7/2012 2:22:51 AM • Ericsson SCREEN... • Answered on May 07, 2012
The letter 'H' has appeared
H refers to HSDPA and HSUPA. This is 3G, so it is basically the same as if it shows 3G.
9/23/2011 10:56:26 AM • Ericsson SCREEN... • Answered on Sep 23, 2011
I could not read the
you can contact the service provider........
7/14/2011 5:52:06 AM • Ericsson SCREEN... • Answered on Jul 14, 2011
How to change the message tone in sony erickson
go to profile and and select the tones you want....
6/3/2011 4:37:50 PM • Ericsson SCREEN... • Answered on Jun 03, 2011
2answers
Mobile lock
hey dude you can unlock your mobile using unlocking codes also , get unlocking code for your mobile just at right here http://www.onlinegsmunlock.com/
6/1/2011 4:36:14 PM • Ericsson SCREEN... • Answered on Jun 01, 2011
How much for the phone
You'll have to do a hard reset of your phone. Here's how to do it:
- With the device powered off, press and hold the 2 soft keys.
- Whilst holding the 2 soft keys, press the Power Button once.
- If successful, you will receive a screen asking you confirm the reset.
Note: it can take a few seconds for the message to appear and you should continue holding the 2 soft keys until it does.Follow the onscreen prompts.
You are going to lose all the pictures, ringtones, videos, music, and such; but this is the only way to use your phone again. Good luck!
Sources
  • http://www.phonescoop.com/phones/p_forum.php?fm=m&ff=1041&fi=1158993
  • http://community.htc.com/na/htc-forums/windows-phone/f/85/p/404/726.aspx
5/24/2011 1:58:29 AM • Ericsson SCREEN... • Answered on May 24, 2011
2answers
My phone is blocked its a sony ericsson c905 its
nothing.... blacklisted handset... you wont be able to makew or receive calls and texts.
5/13/2011 10:48:56 AM • Ericsson SCREEN... • Answered on May 13, 2011
When i turn on my
its a software problem. go chnge ur software
5/4/2011 3:56:01 AM • Ericsson SCREEN... • Answered on May 04, 2011
Quero sabe o puk do meu celular
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
3/15/2011 8:24:09 PM • Ericsson SCREEN... • Answered on Mar 15, 2011
Serius error do not charge, do not use the phone
Are you using a replacement charger or one that is not original? If yes, it's normal to have that error when charging. Remove it then plug it again so you can continue charging. It happened to me when I got a replacement charger and even though it gives me the error, I just unplug it then plug again until the phone is fully charged.
3/8/2011 6:35:06 AM • Ericsson SCREEN... • Answered on Mar 08, 2011
SE PUSO EL CODIGO DE USUARIO Y NO ME ACUERDO CUAL
solo con firmware update
3/1/2011 1:26:02 PM • Ericsson SCREEN... • Answered on Mar 01, 2011
No display on my wy595
while there is no display on your phone, can you still receive calls? If yes, then it means there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
I hope you understand the above and I also hope it is helpful.....
Good luck.
2/26/2011 2:11:48 AM • Ericsson SCREEN... • Answered on Feb 26, 2011
Heeey, my sony ericson phone has locked its self
Hello
Have a look at the link below. You will be directed to a tip i wrote on how to recover your PUK code.
Click HERE.
Kind regards
Lock123
1/19/2011 8:32:18 PM • Ericsson SCREEN... • Answered on Jan 19, 2011
I want to know the
The default phone lock code for all the sony erricsson is 0000
If this don't then u or someone might change it.
And if u don't know the code then pls go to your nearest phone repairing service and ask to reset the password
1/10/2011 4:42:52 AM • Ericsson SCREEN... • Answered on Jan 10, 2011
Ericsson SCREEN PROTECTOR MEXXPROTECT Crystal-Clear for Sony  W595i, W-595i, 100% fits, Display Prote... Cell Phone Logo
70 questions posted
Top Ericsson Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Ericsson Cell Phones
Most Popular Question
remove air bubbles from cell phone
  • Cell Phones
