20 Most Recent Canon PIXMA MP240 All-In-One InkJet Printer Questions & Answers
  • kishor kumbharePrinter canon mp258 scane problem error code 2,140,2
    May 05, 2013
    May 05, 2013
Canon PIXMA... | Answered on Dec 04, 2019
Your printer might be running out of ink, if you've seen that the ink button blinks, youy need to replace your cartrudge or refill your ink.
Canon PIXMA... | Answered on Sep 11, 2019
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Canon PIXMA... | Answered on Oct 29, 2018
The E3 eeror is a paper jam error.
First, Unplug the printer from the power cord. Disconnect the printer cable as well.
2nd, open the covers and using a flashlight, look for any small debris inside the printer. The smallest piece can trip the error. Remove anything you find.
Next, get some "canned air" at any computer or office supply store and blow the inside of the printer thoroughly. You may even turn it upside down so debris can fall out.
Plug it back in to the wall socket and connect to your PC again and give it a try. That should resolve the issue.
Canon PIXMA... | Answered on Jan 22, 2018
It could be a faulty power supply, or a jammed carriage belt motor. The power supplies can be replaced but given the age of the machine, it is likely to be developing other issues. I would recommend saving yourself some grief (and money) by replacing it with a current equivalent version. If that is not an option, locate the power unit and remove it. It's usually on the bottom and held in by two clips. Remove and locate the model number. Then try contacting an electronics recycling centre to see if they have one.
Canon PIXMA... | Answered on Nov 16, 2017
Looks like you installed the wrong driver. Better to download the latest drivers from Canon website
Canon PIXMA... | Answered on Sep 16, 2017
ppada printer canon error P.1.0 printer tdk bekerja
Canon PIXMA... | Answered on Aug 18, 2017
Not sure about your machine but my Cannon would not work when my colour ink was low. The store I bought it says the manufacturer does this to sell coloured ink as well as black. The setting might say for black ink but there is a certain amount of colour goes in as well. I hardly ever used colour as I do business letters so I purchased a black ink jet which uses a black powder and I get 3000 pages for about 75 dollars worth of black jet powder.
Canon PIXMA... | Answered on Aug 12, 2017
Go to the Canon support website and download all the software for the printer.
Canon PIXMA... | Answered on Jun 22, 2017
none of the above work. Thanks for trying
Canon PIXMA... | Answered on Jan 03, 2017
there a small plastic sensors on paper path, normaly you have some sensor stucked.
you can check all paper path inside printer, there is a paper door nearby power input. open-it and locate the sensors small plastic finger check for free mooving operation.
normaly is one of three sensors (one for no-paper, 2nd for middle of paper path and one for paper position nearby print-head, test path with a paper, for free path.
Canon PIXMA... | Answered on Sep 14, 2016
Canon PIXMA MP240 All-In-One InkJet Printer Logo
874 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon pixma mp240 all in one inkjet
  • Office Equipment & Supplies
