20 Most Recent
Lexmark X2650 All-In-One InkJet Printer Questions & Answers
Lexmark X2650 3-In-One Printer/Scanner -
your problem may be ur power adapter has gone out... try replace by checking your input volts and ampere as well as output volts and ampere. you can use compatible also. if same problem occurs it might be the power supply area problem inside the printer
Hi my lexmark x2650 keeps
The EC5 error code indicates a short has been detected in one of your cartridges. Open the printer and remove both cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any errors. Open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error to pop up. Or you can try to insert a different known working cartridge to determine if the other is faulty.
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will
need to install the Lexmark OCR scan software on your computer. The Lexmark
scan software (no downloadable version) is only available on the installation
disc that came with your printer. If you lost the disc, please contact Lexmark
Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
- Insert CD into the CD-ROM
drive. If the installation screen open, click Cancel.
- Double-click on My Computer /
Computer.
- Right-click on Lexmark XXXX CD
and select Open.
- Double-click on OCR.
- Double-click on Setup.exe to
install the OCR software. Your operating system will then determine the
language in which it is installed.
Is this printer wireless? or do I have to use the usb cabl to print?
it seems that wireless is not supported, and you must use a USB cable. Check that the connectors are the correct ones; printer accepts a type B ('house') male connector (plug)
If uncertain consult Lexmark support, or the manual for this printer. Information (including probably a manual) can quickly be obtained from the webpage
All Products Printers MultiFunction Lexmark X2650 Lexmark
The image shows two connectors (which may be on either end of a single cable, and what I think you need) lower is type B (printer end) , upper is type A (computer end, most commonly). Available in various lengths, you need USB 2.0 spec.
