20 Most Recent
HP Mini 1000 Netbook Questions & Answers
Caps lock always on
well the keyboard is bador the driver for it is badif external keyboard USB worksand bios tests of the keyboard is okay.then the driver in w7 are wrong, missing or corrupted.or the OS is fully corrupted.Boot to free linux boot media see if linux likes that keyboard.desktop keyboards USB do work on laptops. triedyes/now7 fails yesbios failsexternal USB KBD fails.Lunux fails (demo medial) "ubuntu try me??"does HP.com say they support w7 on this PC.if yes load all HP.drivers from HP.com and it is cured, if not a bad keyboard;.
Netbook
pay for faster internet at ISP$$$$
use ethernet
use faster wifi card, AC or AC grade.
get a faster router, wifi, (AC or AX) grade
I cant download softwares or
reload the OS. (no OS stated by you, windows what?)
on all hp, press the F11 key at power on.
power on , and quickly hammer the F11 key (recovery)
next see the recovery page.
now pick fully restore
if you have data to save ? , that would be first,
then recovery,
this works on all HP from 2006 to now.
what you lack is Admin privileges. (power words)
if you had told the OS you run, there are hacks to make that work in most cases. (not so easy on w10 )
to test this fact
go to control panel
click users, see you? your login, name sure, click that and try to
set admin, privileges, it will now let you. nor let you manage other accounts, that is because your login is using non admin mode.
How do i close an open window on my netbook
Just Press the cross button on the top right. If it is hanged then press Ctrl>Alt>Del together and click start Task Manager. Then on the dialogue box, select the window you want to close and then click END TASK. Hope this helps
I cant locate my blutooth
Without basic information such as
Operating System, Device you wish to connect (mouse, keyboard, headset, etc.) and whether it worked before or has never been turned on??
The best I can do is offer the most common
solution; here's the link to everything pertaining HP's, Notebook, Bluetooth Connection. If you only want to turn it on, these instructions are clear enough.
Hp Mini 1000 Blue Tooth: Enable/Disble.
Thank You For Choosing FixYa~!
How do I get the pass word back
If you've forgotten your windows password, you can always boot a livecd of Kali linux and use chntpw to blank the Windows password found in the SAM file for your account. This will fully clear the password, allowing you to log in without one.
When I try to run
acutually you dont need to wory much about the failed updates. it wiil come again next time when your system automatically updates. ther is no harm if you update failed.most of them are security updates. a good antivirus will work fine.dont wory,
good luck
How to boot in safe mode
To get into the Windows XP or Vista and Windows 7 Safe Mode, as the computer is booting, press and hold your "F8 Key", which should bring up the "Choose Advanced Options" screen as shown below. Use you arrow key to move to "Safe Mode" and press your Enter key.
Change a desktop background
XP - Right Click the desktop, go to properties then look through the tabs and you will find one for desktop backgrounds.
Win 7 - Right Click the desktop, go to personalize, then click desktop background, then select the background of choice
