20 Most Recent Toshiba Tecra M5 Notebook Questions & Answers
What is "Platform Attack"?
Toshiba Tecra M5... | Answered on Apr 18, 2014
Hi. Please click here to download the .pdf maintenance/service manual for Toshiba Tecra M5.
Toshiba Tecra M5... | Answered on Apr 22, 2010
try uninstalling the touchpad driver from your device manager then reboot...
Toshiba Tecra M5... | Answered on Nov 16, 2009
If the problem is intermittent then the problem could just be foreign objects like crumbs and hair that's trapped under the keys.
Turn the laptop off and stand it on it's side with the lid open. Get a soft, dry paintbrush and brush the keys, gently tap the keyboard in various places with the back of the paintbrush to help dislodge anything that's trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
If it has not then you may need to replace the keyboard.
Good luck.
Toshiba Tecra M5... | Answered on Sep 16, 2009
Download all the drivers for Tecra M5 from Toshiba support here >>>>>>>>>>
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1277458&rpn=PTM51U&modelFilter=M5&selCategory=3&selFamily=1073768664
Good luck
Toshiba Tecra M5... | Answered on Jun 22, 2009
You need to build a hardware device that plugs into the printer port.
Get a 25 pin male D sub connector, and solder various wires
to the pins numbered below. The pins on the connector are numbered 1 to 25
For a picture of this hardware device (dongle) go to :-
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg
Connect these pins together by soldering thin insulated wires to the following pins :-
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle in the printer port and boot up the laptop, you will then be able to bypass the BIOS password and go into the BIOS to reset/remove the password.
Toshiba Tecra M5... | Answered on Mar 09, 2009
remove the hdd and attach to desktop .
right click in my computer and run check disk in tools section in drive properties
Toshiba Tecra... | Answered on Sep 25, 2017
1. try with clear cmos and remove AC adapter and main battery.
2. also pls try to remove the code with password re set web site or password remove tool in hiran boot cd
need more information to determine the fault. but you can remove the battery and pls plug ac adapter and also re seat the RAM. power on and test
You could purchase a new hdd and install your OS then drivers from Toshiba and then restore your backups or type the password correctly.
Toshiba Tecra... | Answered on Apr 14, 2016
you need to contact YAHOO to do that . we can not SORRY
Toshiba Tecra... | Answered on Sep 24, 2015
I have had this on an iphone 5. Apple sold me a new phone as it was not worth repairing and it was out of the 12 month warranty. Its possible to order a new part and do it yourself but unless you are totally confident and have the skills to open up your phone and reassemble it then its just not worth it.
Toshiba Tecra... | Answered on Apr 18, 2015
What is the actual question?
Toshiba Tecra... | Answered on Feb 02, 2015
look closely at the keys along the top of the keyboard (usually called F keys). one of them should have a tiny sun icon and the key beside it will have a larger sun icon. hold down the "Fn" key elsewhere on the keyboard while pressing the one of the sun icon keys to brighten or darken the picture. the sun icon keys may also be located on the Arrow keys (<-- --> etc.)
Toshiba Tecra... | Answered on Jan 31, 2015
If they are shop bought CD's then suspect the drive, if recorded on another pc, finalize them first.
Toshiba Tecra... | Answered on Jan 26, 2015
Could be a very easy fix....does your computer seem a little to warm when this happens? If so the fix for this could be getting a better fan.
Sometimes when laptops run too hot they have a safety that shuts it off to prevent damage from heat.
You can find laptop fans pretty cheap on some computer part sites, also making sure your laptop is free from dirt and dust helps keep the temp down.
Toshiba Tecra... | Answered on Dec 31, 2014
Look at your manual.
Toshiba Tecra... | Answered on Nov 28, 2014
It unclips and slides away from the base.
When does it open on its own?Sometimes it is easy to be press the open button as you close it which of course opens it straight away.It can also fail to lock closed if not opened further than its initial amount that it does open.To close it after it opens you need to draw it back to rearm the mechanism.
Toshiba Tecra... | Answered on Sep 02, 2014
You might try taking the battery completely out for about 60 seconds, and see if this does not reset whatever got hosed. Also, unplug any external devices (like wireless keyboard/mouse, SD card reader, ...) that may be trying to use the PCI buss, just in case something is hosed with them.
Toshiba Tecra... | Answered on Aug 04, 2014
Toshiba Tecra M5 Notebook Logo
6 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Tecra Toshiba
  • Tecra Toshiba
Most Popular Question
toshiba wifi driver tecra m5
  • Computers & Internet
