20 Most Recent
Samsung Sway SCH-U650 Cell Phone Questions & Answers
My touuch screen is not charging when i plug it in to the computer how do i fix it
Hi Joey Miller there are a few things you can do to fix this problem. One is clean all ports on your computer and the phone. There could be dust in any of the ports. Next go to settings on your phone. This is not commonly know or done. In the settings you need to scroll down to the usb connection. It is going to ask you how you want to connect. it should be three choices ask on connection will allow you to charge your phone on the pc. But you will not be able to use all the phone functions. I’m happy to help further over the phone at
https://www.6ya.com/expert/ronald_e152e07e272e4f27
Up,right and clear button not working when opened
i have the same problem on my phone and i was unable to fix it but i could get the clear, up, and left buttons to work by sliding the screen down a tiny bit until the buttons on the screen light up (they are not lit up when the phone is slid out). you won't be able to push the top row of keys, but by sliding the phone slightly down you should be able to use the clear, up, and left keys
NAM 2 unlock code
I did the same thing... I found this & IT WORKED!! the URL is http://www.blurtit.com/q1652331.htmlit's super easy & only takes a second to do. Hope this helps. Blessings. -~myleshigh
I just bought this samsung
The best thing to do in this case is to take the phone into your provider, and see what they say. They can check it out, and possibly reflash the phone, and get you going, or let you know if there's a problem that will require servicing.
Good luck,and hope this helps.
