20 Most Recent
Apple iPhone 3G Black Smartphone Questions & Answers
My iphone 3g is slow
The iPhone can be slow if you have too much on the disc. Closing running apps should also lakenene iPhone faster.
By mistake i had deleted all the contents of my
Plug your iphone into your computer via usb. open itunes and it should prompt you to do a restore. once restored you can select the most recent backup of your iphone. (the last time you plugged your iphone into your computer it backed up your info) Once selected you itunes will load all of your saved data back onto your iphone.
To transfer pictures from iphone to computer
Use the bluetooth to connect your Iphone to the PC.
Open menu - connectivity and click bluetooth to ON.
You can also open the picture and use right key to send via bluetooth. The laptop must be On as it will detect the bluetooth, accept and get all the files send.
My unlocked Iphone 3g 16gb will not unlock.
Have you ever tried iTunes with Recovery mode? Follow below steps to use iTunes Recovery mode to unlock your iPhone.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
- 1. Turn off your iPad Air, press and hold the Home button.
- 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
- 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
- 1. Connect your iPad to your computer or laptop and open iTunes.
- 2. While your device is connected, force to restart it.
- 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
For more methods, check:
How to Unlock iPad
The apple logo on my phone wont go away and the
try holding down just the sleep/wake button till screen goes black, then hold down the home screen button and plug into iTunes and wait for iTunes to say:
iTunes has detected an iPhone in recovery mode......
then let off the button set phone down and hit ok in iTunes then restore to factory..
"Check Operator Services" when sending a text
most probably you have disabled the CLI thing. In which your cell tries
to prevent your number being shown to the person you are calling.
It is usually under Network settings, or Call settings (CLI/Show my number/Send my Number).
I deleted an important text message by mistake
Yes, there is a way to recover your iPhone SMS.As a matter of fact, every time you sync data between iPhone and iTunes,
all previous data will be automatically backed up by iTunes and stored
as a .sqlitedb file, which will be updated along with the later sync
continuously. But those backup files can't be viewed or taken out unless
you use some software using special algorithms to extract.Learn
how to recover your iPhone data here with step by step guides.Good luck!
I want to print out my text messages in my iphone
Option 1.
I'm wondering if it's possible to print a text message from my iPhone? Perhaps forward it somehow to the MacBook Pro and print from there?
You can do this with Ecamm Networks' $20 PhoneView. Among PhoneView's many talents (including using your iPhone as a storage device when connected to your Mac, copying the iPhone's music, videos, and photos to your computer; and viewing and editing the iPhone's notes) you can export the phone's SMS messages as text files, which you can then print.
It's easy to use. Install it, plug in your iPhone, and PhoneView launches. To access the phone's SMS messages, just click the SMS entry on the left side of the PhoneView window. You can copy individual messages, Command-click to copy several messages (helpful when you want to copy just those messages that are part of a particular conversation), or copy all messages by selecting one message, pressing Command-A to select them all, and clicking the Copy From iPhone button at the top of the window.
Option 2.
You can take a screen shot of the page by pressing the home button and the wake/sleep button at the same time. you will see the screen flash. Then, add that pic to an email to yourself. From your home compputer, access that email, and print from your computer.
Option 3.
Transfer your text messages from iPhone to pc using Tansee iPhone Transfer SMS.
http://www.gutensoft.com/Utilities/Tanse…
This is what I've used.
It can help you transfer all text messages on iPhone to computer in the formats of Text file format (.txt file) or ANTS file format (.ants file) .
Besides, you can choose to transfer from all contacts or a single contact. How did it work? Just great.
I give my highest recommendation to it. It even has step-by-step guide.
Source(s):
Option 4.
here's a $5 option that pulls the texts from your backup file:
http://www.macworld.com/reviews/product/592840/review/decipher_textmessage_14.html?expand=true
Option 5.
believe iphone backup extractor (free) may let you do it.
http://supercrazyawesome.com/
Broken glass touch screen to iPhone
Hello.
Here's some info about your iPhone display repair:
Repair/replacement from Apple: $200-$250 The iPhone is covered under a
standard limited one-year Apple warranty for manufacturer's defects, but is not
eligible for AT&T's wireless phone insurance, which (for a $5 monthly fee)
will provide replacement in the case of loss or theft, accidental physical or
liquid damage or mechanical and electrical failure after the manufacturer's
warranty period has expired.
Apple will repair your iPhone for the service fee listed below, plus $6.95 for
shipping and handling:
Do-it-yourself: $150-$200 tools and loss of your warranty Several
third-party companies sell replacement iPhone screens, which include the LCD and
associated components. PDAParts sells the complete replacement screen for $150 and has a how-to-video for
self-installation.
Hope this helps.
How can I recover accidentally voice memos from
When you lose your voice memos in your iPhone, they can have a look at your iTunes first, maybe you've synced the voice memos to iTunes, and the voice memos can be found in iTunes folder. If not, you may need to restore your iPhone with iTunes to recover deleted voice memos. If you have updated your iPhone backup in iTunes, you will save the voice memos in iTunes backup as well, so you are able to get the lost voice memos back with iTunes.
When the restoring process is done, you will get the backup contents in your iPhone. The voice memos should have been restored to your iPhone as well. However, as is known, there is chance that the iPhone users will lose the newly added data in their device if they haven't updated their backup. At this moment, you will need a piece of iPhone data recovery software to recover deleted voice memos from iPhone backup.
http://www.leawo.org/tutorial/how-can-i-recover-deleted-voice-memos-from-iphone-6.html
Is the Iphone data plan mandatory?
Try going into your phone shop and asking them if they can upgrade it for a good price rather than buying a new one that has the internet. If they dont then maybe buy a cheaper phone that has internet or keeping ur phone and seeing if they have any wireless plug ins to plug into ur phone to have the internet. Otherwise you may have to buy the newer phone. Hope that this is helpful to u!
