20 Most Recent
Samsung SGH-i8510 INNOV8 Cell Phone Questions & Answers
Charged paused
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
8/16/2012 4:07:06 AM •
Samsung...
Answered
on Aug 16, 2012
I forgot my simlock code,
You may contact to your network provider
Samsung SGH-i850 Unlock Code, they will provide you an accurate code with easy to follow instructions on how to unlock your phone. I suggest to visit
Samsung Unlock Code site, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
5/1/2012 9:28:59 AM •
Samsung...
Answered
on May 01, 2012
How to unfreeze samsung behold
If your phone displays the 'phone freeze deactivation fail' then your phone has gotten hard-locked; it will not accept any unlock codes. This problem can only be caused by improper unlocking. Basically this happens if you or someone else has already entered 5 wrong unlock codes on your phone.You can get the unfreeze code, NCK code and SPCK code from third party. After unfreeze your phone, you have to enter the NCK code to unlock and use it with any gsm network in the world. i will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website
11/16/2011 10:09:07 PM •
Samsung...
Answered
on Nov 16, 2011
My phone is not responding
It is possible that the phone has problems in the hardware , a possible mother board failrue as there is no life on the phone. So to confirm it this a case where the phone has hung up because of errors in the software we need to reset. So remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
7/29/2011 7:37:00 AM •
Samsung...
Answered
on Jul 29, 2011
I saw some dust accumulated
Using a small pocket knife blade or some other thin edged tool, start at one of the bottom sides, near the screen cover's hinge, and carefully pry off the cover, loosening as you go. The glue that holds the screen cover on is a tacky substance and will re-stick after you've cleaned the screen. Slowly and carefully slide the knife along the edge of the flexible plastic, and lift it up as it pulls free of the adhesive.
You can leave the bottom of the screen attached while you wipe with a very soft cleaning cloth or compressed air. Remove the dust off of the screen and then simply press the screen cover back down and run your thumbs around the edges to reseal it.
That's all it takes, and you don't need to buy any fancy tools.
7/19/2011 8:54:06 AM •
Samsung...
Answered
on Jul 19, 2011
I want sent txt by mms on my samsung inno8 phone
Since there's no separate MMS message menu on Samsung, you wont be able to send a normal and simple text message as MMS, but if you wish to send text only without any graphics or multimedia, you can try inserting a multimedia like image or sound clip before you start editing the message, after that type in the text and delete the multimedia content once you finish entering the text. This method works on Gorby, I've tried it myself. But I am not very sure whether it's the network or the model.
It's also not recommended to sent text message as MMS since you would be charge for the service. As long as there is no multimedia content, I would suggest you to send text only message as text message instead of MMS.
If my assumption is wrong, please clarify with more details.
Good Luck.
Thanks for using FixYa.
3/6/2011 1:55:15 PM •
Samsung...
Answered
on Mar 06, 2011
