20 Most Recent Haier Freezer HUF168PA 16.8 Cu. Ft. Upright Freezer Questions & Answers
there is a loose connection at the rear of the freezer near or around the compressor unit , i strongly advise you to get a professional to look it.
Regards
Haier Freezer... | Answered on Dec 16, 2012
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Haier Freezer... | Answered on Jun 12, 2011
The thermostat is bad....
You will need to replace that t-stat..
That is not that hard to fix and you can easilybuy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Haier Freezer... | Answered on May 17, 2011
ur overload chip is triggering, check r134 charge , or start relay, and condeser, otherwise ur compressor might be damage..
Haier Freezer... | Answered on Mar 15, 2009
it often works to warm the seal with a hairdryer and reshape it
Haier Freezer... | Answered on Nov 29, 2008
MIGHT NEED A SERVICE REPAIRMAN TO ADD FREON
Haier Freezers | Answered on Dec 20, 2019
you search on net.
Haier Freezers | Answered on Dec 13, 2019
Check it has power. Phone a repair engineer.
Haier Freezers | Answered on Nov 28, 2019
You can try resetting it by unplugging it for 10 minutes.
The Ed error code is referring to the defrost heating system.
Haier Freezers | Answered on Oct 28, 2019
If compressor isn’t running, it’s either a thermostat / control board problem, or a power supply problem.
Haier Freezers | Answered on Jan 30, 2019
If compressor isn’t running, it’s probably a thermostat problem
Haier Freezers | Answered on Oct 11, 2018
1 = On.
0 = Off
Haier Freezers | Answered on Oct 04, 2018
https://www.manualslib.com/brand/haier/freezer.html
Identify the model and free manuals online at the link shown.
Haier Freezer manuals
Haier Freezers | Answered on May 24, 2018
Haier Freezer HUF168PA 16.8 Cu. Ft. Upright Freezer Logo
7 questions posted
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
View Most Popular
Haier Freezers
  • Haier Freezers
Most Popular Question
freezer compressor turns minute shuts
  • Freezers
