20 Most Recent Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA Questions & Answers
Freezer not working or not getting cold and i
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
2/2/2011 4:39:13 PM • Haier 5 cu. ft.... • Answered on Feb 02, 2011
2answers
Beko frost free fridge freezer keeps icing up
hi there.....sounds as you need a new defrost heater unit fitted.....if your unsure how to do this contact beko service.....
regards Sir Galahad
2/5/2010 1:01:57 PM • Haier 5 cu. ft.... • Answered on Feb 05, 2010
My freezer no longer freezes. were do start to
bin it. it is cheaper to replace than repair.other than the fuse that is.
2/5/2010 12:59:11 PM • Haier 5 cu. ft.... • Answered on Feb 05, 2010
Litters in terms of watts
air/water volume in cavity
2/5/2010 12:58:05 PM • Haier 5 cu. ft.... • Answered on Feb 05, 2010
WONDERING WHAT THE SWITCHS ARE FOR. I HAVE A
orange is fast freeze,green is on,
2/5/2010 12:56:37 PM • Haier 5 cu. ft.... • Answered on Feb 05, 2010
THE GREEEN LIGHT COMES ON BUT NOT THE COMPRESSER AND IT IS NOT CO
Bypass the cold control and see if it comes on. If it does then change the cold control if it dont then examine the compressor relay and see if it is burned up. If the compressor relay ain't it then you have a bad compressor. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3/7/2009 10:20:21 PM • Haier 5 cu. ft.... • Answered on Mar 07, 2009
0answers
My haier 5cu.ft. freezer stop freezing
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
11/29/2008 12:18:47 AM • Haier 5 cu. ft.... • Answered on Nov 29, 2008
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
11/8/2008 2:37:52 PM • Haier 5 cu. ft.... • Answered on Nov 08, 2008
2answers
Installation manual for walk in freezer
you search on net.
4/30/2021 2:53:27 PM • Haier Freezers • Answered on Apr 30, 2021
What does Ed mean on a haier freezer and how do I get rid of it
You can try resetting it by unplugging it for 10 minutes.
The Ed error code is referring to the defrost heating system.
10/28/2019 11:50:26 PM • Haier Freezers • Answered on Oct 28, 2019
How to stop the alarm going off on an upright Haier freezer.
https://www.haierappliances.com/support/freezers/troubleshooting try this web site for direct answers from the manufacturer.
5/29/2019 1:43:04 AM • Haier Freezers • Answered on May 29, 2019
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA Logo
15 questions posted
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
View Most Popular
Haier Freezers
  • Haier Freezers
Most Popular Question
wondering switchs
  • Freezers
