20 Most Recent
Sierra Online, Inc. Hoyle Classic Games 2 for Windows Questions & Answers
I am trying to install an old sierra hoyle
you can try running it in compatibility mode, when installed right click the desktop icon, then go to bottom of list to properties, then on the thumb nails, look for compatibility look in the list for what ever program it was made for ie windows xp, windows 95, then try that there are more settings there which may help...hope this helps
I have windows 7 and trying to install my
A lot of your older games, especially those designed for Win 95, 98, 2000 will not work on current generations of Windows. What you could try to do is run emulation software to emulate one of these environments. The only drawback to this is that not only will you need the emulator (which is usually fairly cheap), you would also need a legitimate older copy of windows to install.
Your only other real option would be to browse ebay and maybe find an older comp that someones just looking to get rid of. Depending on your level of expertise setting up the rarely used emu software this may actually be a quicker and less stressful route.
Other than that, I can't really think of any other options you would have other than the Windows XP mode if your version of Win 7 is fortunate enough to be Professional, Ultimate, or Enterprise. If you are lucky enough to have one of those than this link should put you in a good direction.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
Have a 1998 disk with
You can find the file that it is stored in. Right click on the executable and change the compatibility to start in windows 98. This should fix your problem
How do I only install a few of the games instead
hey there welcome to fixya
you will need to install the games one by one by exploring the disk and finding it manualy or you can explore the disk on auto run and do it one by one
please remember to rate this solution
regards
magical ink
New computer won't install board games disc
check software comaptibility list. chances are if its an older game it wont run on XP, Vista or Windows 7. if your using another operating system i cant say much however i would expect the same issues with their newer operating systems.
The Aces of the Galaxy game
Try to find your settings on the game, and see if you can change that, or it might be a bug and you should report it immediately to the manufacturer
I have an old version of Hoyle Mahjong.
Right click the installer file. Go to compatibility tab and select Run this program in comparability mode for and select win95 from drop-down list. Reinstall by clicking it.
Trying to install an older Hoyle Solitaire and Mahjong game
Once you insert the CD, go to Start -> My Computer, and Double Click on the Drive that has the Hoyle Picture. This will either start the Installer/Auto-run window, or it will open a series of files. Double click on Setup.exe if it does not autorun.
I bought a new computer. When I tried to run
To be honest, there are only two options.
1. Go to the sierra online website and see if you can get a 64 bit version of the game
2. Get an entirely new OS of windows (a 32 bit version) and then try installing
Empire earth 1 not running in windows 8
Empire Earth is not supported on Windows 8, . You will need to manually edit the registry. You need to open "Run" (can do it by pressing the "Start" keyboard key and then "R"), type "regedit" and then click "Ok".Navigate to "HKEY_CURRENT_USER\Software\SSSI\Empire Earth\Wait for VSync" and change it to "0" (do this by double clicking the entry).Then navigate to "HKEY_CURRENT_USER\Software\SSSI\Empire Earth\Rasterizer Name" and change it to "Direct3D Hardware TnL" (similar to how you did with VSync).
When i try to run Ultra Mini Golf Adventures, I
HI, just wondering if you have the original disc for Ultra mini golf adventures ?
the error message "A required security module can not be activated" is generated by a piece of software called securecom that is essentially to stop people pirating games.If you have any emulation software such as daemon tools or alcohol 120% (these create a temporary cd drive so that a bit of software can work with out the original cd) running remove or disable them.
If its a legit copy of the game etc.. and you have the cd then it may be an issue with the registry area of your pc
Click the start button and then click RUN
type in regedit
look for the folder
HKEY_LOCAL_MACHINE/System/MountedDevices/
Right click the folder folder, Click Permissions, Click Advanced,
Look under the "TYPE" header for any labels that say "Deny", if there
are any highlight and click Edit, Check Full Control and "OK".
hopefully this should sort the problem
If its not a legit copy or if you have emulation software running you will need to download the latest version of cureom
http://cdmediaworld.com/hardware/cdrom/cd_utils_8.shtml#CureROM
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
