20 Most Recent
Haier BC112G Wine Cooler Questions & Answers
Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Haier wine cooler
Haier BC112G service & user manual: To adjust the temp of your unit:- Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
BC112G Wine Celler Not Cooling
Open the terminal box ontop of the compressor. Check if there is a thermistor inside. If there is, check the continuity. If the continuity is alright, check the winding resistance of the compressor. If the winding resistance is good, then the fault is in the controls.
Breezair unit freezs up in my wine cooler---- why.
Does it run constantly? If so, an easy test fix is to go to WalMart and buy a timer that cycles in half hour intervals. Play with the on/off settings and see if that stops it from freezing up.
May be the thermostat, which is a fairly easy fix.
May be low on Freon.
I have a Haier wine
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
