20 Most Recent Mitutoyo Dial Calipers Questions & Answers
3answers
The face on my dial
4/21/2016 7:43:45 PM • Mitutoyo Dial... • Answered on Apr 21, 2016
How do I change the battery in a digimatic model # cd-6
In mitutoyo digital vernier battry inserted upper portion side by display you battry cover theire is an arrow mark downward release you will find battery in side remove it and put new one battery code Sr 44 you will from marketor in mall try it
12/29/2015 12:16:18 PM • Mitutoyo Dial... • Answered on Dec 29, 2015
2answers
The face on my dial calipers is turned 90 degrees
There should be a small set screw you can loosen by hand and adjust the face of the dial to zero with the jaws closed....this is typical of most calipers...it allows you to zero the dial on a given thickness of material and only read variations based on that thickness.
Take care.
12/29/2015 9:28:35 AM • Mitutoyo Dial... • Answered on Dec 29, 2015
Instruction manual
Caliper Go here - http://bit.ly/1CKf9Wa http://bit.ly/1CKf9Wa
4/12/2015 10:00:27 AM • Mitutoyo Dial... • Answered on Apr 12, 2015
I want a free manual please
go here - http://bit.ly/1CKf9Wa
4/12/2015 9:52:50 AM • Mitutoyo Dial... • Answered on Apr 12, 2015
Changed the battery but still not working
-Possibly broken caliper. Check battery contact if it's bend or broken. Good luck Mai
8/27/2014 8:40:31 PM • Mitutoyo Dial... • Answered on Aug 27, 2014
I HAVE A MITUTOYO 6
The answers above by Kerry Littleton have nothing to do with our calipers. The answer above by Bob Pulver is well-intentioned but doesn't address the real issue.The real issue is the ORIGIN button is little-used and a bit reluctant to "make". The solution is to use a blunt plastic probe to REALLY PUSH down the button and hold it. The caliper will reset to zero.
2/3/2013 6:34:59 PM • Mitutoyo Dial... • Answered on Feb 03, 2013
2answers
I have p# 505 645
Don't take it apart just get a toothbrush or small fine wire brush and clean out the teeth.Use an air gun to blow out behind the dial as well but only on the frame and not the dial part itself. Also check to make sure that the locking mechanism is loose enough as this will cause it to feel like it is jamming.
12/22/2012 3:59:21 PM • Mitutoyo Dial... • Answered on Dec 22, 2012
My caliper is .030 off of zero I don't know how
Just loosen the screw that clamps the dial in place, close the jaws, and turn the dial to zero. Then tighten the screw clamp
11/17/2012 3:32:22 PM • Mitutoyo Dial... • Answered on Nov 17, 2012
Pointer is approximately 0.010" out
As far as I know there isn't a way to get them any better than .01 without sending them in for repair. you can try longislandindicator.com for repairs
5/11/2011 4:46:06 AM • Mitutoyo Dial... • Answered on May 11, 2011
The bezel clamp and knurled knob have dissapeared
longislandindicator.com is the only place i am aware of besides going back to the factory
5/11/2011 4:22:46 AM • Mitutoyo Dial... • Answered on May 11, 2011
How to disassemble dial calipers
I wouln't do it, you will strip the rack & gears. But if you must, a 10 pound hammer would make short work of it.
9/11/2009 4:23:24 PM • Mitutoyo Dial... • Answered on Sep 11, 2009
I have an error on my mitutoyo CMM showing E650 on Joy stick
Verifica la presi?n de aire en la v?lvula de presi?n en la parte frontal de la cmm
12/27/2023 12:38:50 PM • Mitutoyo... • Answered on Dec 27, 2023
Assembly of Mitutoyo 6" micrometer
Repair, Calibrate or Request Field Service
Mitutoyo https://www.mitutoyo.com > Contact Us Whether you need immediate repair service or A2LA Accredited, NIST-traceable calibration of your measuring instruments, our highly skilled technicians ...
12/10/2023 5:31:06 PM • Mitutoyo... • Answered on Dec 10, 2023
Mitutoyo micrometer/caliper. How do I install new glass/plastic dial cover on 6 Mitutoyo micromonitor / calipher.
Mitutoyo https://www.mitutoyo.com > Contact Us Whether you need immediate repair service or A2LA Accredited, NIST-traceable calibration of your measuring instruments, our highly skilled technicians provide ...
Mitutoyo Repair and Calibration
Indicator Repair https://www.indicatorrepair.com > manufacturers > mit... Indicator Repair repairs, restores, refurbishes and calibrates all makes and models of Mitutoyo indicators, micrometers, gages, calipers and levels. ..
12/10/2023 5:23:26 PM • Mitutoyo... • Answered on Dec 10, 2023
Mitutoyo Dial Calipers Logo
22 questions posted
Top Mitutoyo Measuring Tools & Sensors Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Mitutoyo Measuring Tools & Sensors
Most Popular Question
want free manual please
  • Measuring Tools & Sensors
