20 Most Recent Hobart D300 Stand Mixer Questions & Answers
2answers
D300 hobart mixer
i have a spare unit for dsale 1500.00 cdn
2/10/2024 8:17:20 PM • Hobart D300... • Answered on Feb 10, 2024
Cual es el aceite que usa lahobart D300
Cual es el tipo de aceite que usa una batidora hobart 8168
12/18/2021 8:04:23 PM • Hobart D300... • Answered on Dec 18, 2021
3answers
How do you change the grease in a D-300 Hobart Mixer?
Depending how old the mixer is they used to use oil,now they use grease.Regardless it sounds like a seal is worn.Where is it leaking from?
6/20/2021 2:36:19 PM • Hobart D300... • Answered on Jun 20, 2021
Why does it only run at speeds 1 and 2?
What did Hobart tell you ?
4/15/2021 1:44:06 PM • Hobart D300... • Answered on Apr 15, 2021
2answers
Bought Hobart D300-T at auction
i have another for sale - working 1500,00 cdn
3/10/2021 2:32:18 PM • Hobart D300... • Answered on Mar 10, 2021
My D300T motor is turning but shaft is not. How do I open the shaft area.
Weird sound usually means something in the gear box. I found a copy of the manual which includes many exploded drawings; perhaps something in here might help: http://www.bakedeco.com/ebay/pdf/HobartD300.pdf
8/17/2017 9:25:02 PM • Hobart D300... • Answered on Aug 17, 2017
I HAVE A HOBART MIXER D300 ML#11627 I NEED TO
Goto hobartcorp.com,create a username and then you will be able to find out what your looking for.I know that these mixers used oil when they where new but now changed to grease.Any ? let me know as im a hobart tech a repair these often.
8/17/2017 6:46:59 PM • Hobart D300... • Answered on Aug 17, 2017
3answers
I am looking for a grinding disk for my food
www.hobartservice.com click on "locate an office" and enter your zip.
5/5/2016 3:43:57 AM • Hobart D300... • Answered on May 05, 2016
? Wrong rotation ?
as far as the motor you swapped wires on motor switch two wires either two blacks or one black and white
4/6/2016 4:54:40 PM • Hobart D300... • Answered on Apr 06, 2016
2answers
Bowl Repair
A body shop (automotive) can get rid of the dings, but re-tinning is the trick.
You may consider purchasing a bowl. For example, I could get you a new 80qt bowl for under $500, and a 20qt for under $150.
What is your location? If I can help, let me know.
1/31/2016 4:58:52 AM • Hobart D300... • Answered on Jan 31, 2016
Previously hard wired. How do I connect a power cord?
It doesn't really matter which wire goes to L1 L2 or L3. All that can happen is it will run in the wrong direction. If it does just interchange any 2 of the L1 to L3 connections and this will reverse the motor.
1/1/2016 3:22:22 PM • Hobart D300... • Answered on Jan 01, 2016
2answers
How much grease should I pack into a gear box of a...
pack it full the grease seems to find a way to move a way from the gears after a while so you new grease and pack it in
4/26/2015 9:29:11 PM • Hobart D300... • Answered on Apr 26, 2015
manual
4answers
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
9/12/2014 7:48:05 PM • Hobart D300... • Answered on Sep 12, 2014
2answers
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
9/6/2014 7:47:20 PM • Hobart D300... • Answered on Sep 06, 2014
Shaft stops spinning in first gear when load is put on it, all other speeds fine.
Here's what you need to do first. Check and make sure the bottom nut on the agitator shaft or planetary shaft is tight (This is the part that the attachments afix to). NEXT, take off the lid exposing the top area. THEN tighten up the largest nut (TIGHTENING is in reverse! SO - TO tighten turn nut to the LEFT). When the nut is tight, then turn on the mixer in 1st gear. IF you still do not have 1st gear, then turn off unit and THEN loosen (By turning to the right) this nut by a 1/4 turn or so, then turn on mixer again -- check for 1st gear. If after loosening this nut to where there is no resistance at all and you still do not have 1st gear, then you may have a sheared KEY on one of the gears that controls 1st gear! Did you hear anything pop or break before this happened? Let me know.
8/27/2014 2:15:40 AM • Hobart D300... • Answered on Aug 27, 2014
Hobart D300 Stand Mixer Logo
144 questions posted
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Hobart Food Mixers
  • Hobart Food Mixers
Most Popular Question
hobart d300t mixer oil change
  • Food Mixers
