20 Most Recent
Sony Xperia miro ST23i Smartphone - Unlocked Black Pink Questions & Answers
Skype recorder android
Actually, many Android screen recorder apps need you to root your device before recording the screen. However, you will take the risk of breaking you phone to root your device, and it would be very complicated to root. Nevertheless, I can tell you a root-free trick to record all the moves on your phone, absolutely including your Android Skype. You will know more about recording Android Skype.
Feasible Ways to Record Android Screen
How do i unlock my sony xperia mir if i forgot security question answer
- Make sure the battery charge properly before doing this step
- Do not forget to backup all important data
- Turn off the SONY XPERIA MIRO (ST23i/ST23a)
- Press and Hold together: Power Button + Volume Up Button for several seconds
- Follow the menu at LCD screen to continue the hard reset SONY XPERIA MIRO (ST23i/ST23a)
Unable to listen music in Nokia BH 108
Hi! The Nokia BH 108 headset does not have the A2DP function (advanced audio distribution profile). However, if you are using NOKIA (symbian) non-windows phone, you can play music since the phone bypass the said restriction. You may want to try other bluetooth headsets that has A2DP function so you can enjoy the musics from your headset.Thanks.
Sony xperia miro manual
The easiest way to print an email would be to open the email on a computer with a printer and print it out from there.
If you're asking how to write an email from the phone, you'll need to click on the email app. From there, it'll ask you to sign into one of your email accounts and offer you suggestions like gmail, hotmail, etc.
From there, you just select the email provider you use, for example google mail, then put in your gmail address and password. After that, the phone will synchronize your mail account with the phone. Once that's done, you'll be able to compose an email on the phone using the onscreen keyboard.
How do i set lock pattern
To set a lock pattern, go into the phone's settings, then security. In there, you'll see "pattern unlock" or something of that sort.
From there, you can set the pattern.
Just don't forget it after, or you'll be back on here asking how to reset the pattern if you've forgotten it. :P
I created a password on my phone to be able to use call barring and now i have forgotten my password
since you tried everything, the best solution would be doing a factory reset on yout Sony Xperia phone.. but you have to backup your files on a computer first. To reset it, follow the ff steps below:
- Make sure the battery is not empty, better fully charge
- Turn on SONY XPERIA MIRO (ST23i/ST23a) smartphone
- Don't forget to backup all important data
- Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
- Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA MIRO (ST23i/ST23a)
- The SONY XPERIA MIRO (ST23i/ST23a) will continue the step until ready to use in clean factory default.
